How Does Using Different Active Mediums Affect Laser Output?
  • Level: Graduate
  • Thread starter Grimstone
    Medium
Grimstone
I have no doubt that someone, someone somewhere has tried this.
but if you take a 10 WAT output from a argon beam and run it through a Rubie Active medium chamber I would expect that the light would be excited to a higher range.
Am I in error?
i presume you are referring to the 10 Wat's. one needs a starting point.
Am I in error?
Yes, you are in error. (Presuming by higher "range" you mean frequency).
Why would you expect the light to be excited to a higher frequency with increased pump power?
Claude.
Perhaps the OP means to ask if the light would be amplified to a higher power via stimulated emission, as happens inside a laser.
In this case, I would say no, as Ruby is used to amplify red light at 694 nm, whereas argon lasers produce blue or green wavelengths.
I think you are right. I'm not as smart as you all. I like thinking of this stuff
I prefer stellar physics.
But..I wonder so much about so many things.
So I am going to retry asking my question.
I pump light in go a argon active medium chamber what i get out is 10 WATS of green beam. IF i put said 10 WATS into a red active medium chamber. Will the output of the beam (assume only 1 watt due to the %90 loss) but the beam wave crests would be tighter, yes?
or, would it have no effect at all but to recolor the light to red?
