How Does Work and Potential Energy Interact Between an Object and the Earth?
The discussion revolves around the interaction of work and potential energy between an object and the Earth, particularly in the context of lifting an object against gravity. Participants explore the implications of work done by external agents and the gravitational force, as well as the relationship between potential energy and kinetic energy.
  • One participant proposes that when an external agent lifts an object, the work done is equal to the change in gravitational potential energy, expressed as W=mghf - mghi.
  • Another participant argues that the work done by gravity is the negative of the work done by the agent, leading to a zero net work scenario, which raises questions about energy gain.
  • Some participants question how energy can be gained by the object if no net work is done, suggesting a need to differentiate between the work done by gravity and the change in gravitational potential energy.
  • A participant clarifies that when considering gravitational potential energy, one can disregard the work done by gravity, while in the context of work done by gravity, the change in kinetic energy should be examined.
  • One participant uses an analogy comparing the work done by an external force to income and the work done by gravity to a bank deposit, illustrating the concept of energy storage in potential energy.
  • Another participant introduces a different scenario involving a constant gravitational field and a charged plate, posing a question about the work performed per unit time in that context.
Participants express differing views on how to account for work done by external agents versus gravitational forces, and whether energy gain can occur without net work being done. The discussion remains unresolved with multiple competing perspectives.
Participants highlight the importance of distinguishing between different forms of energy and work, and the implications of conservative forces in their analyses. There are unresolved assumptions regarding the definitions of work and energy in the context of gravitational and external forces.
Perrin
Hello, I got another inquiry about work. Supposing an external agent gives potential energy to an object by pulling it up for instance, he's doing work equal to:
W=mgh_{f} - mgh_{i}
Now, at the same time the Earth is doing the same work, only negative. Only, when the object is let go, it still possesses the same energy obtained by the external agent, without subtracting the work done by the earth. Why is that? How does the work done by the Earth at that time manifest?
Thanks for the stellar help.
Here's how I would put it. If an agent lifts an object with a force equal to the object's weight, it does work on the object equal to mghf - mghi. By doing this work against gravity, the gravitational PE is increased. If you look at gravity as another force, then the work done by gravity is negative of the work done by the agent: Thus the change in KE is zero, no net work was done.
Either consider the work done by gravity or consider the change in gravitational PE. But not both, since they are just two ways of saying the same thing.
OK, so the work done by gravity is actually manifesting in the fact that no KE is gained by the object?
If no net work is done though, how can it be that there's energy gained by the object?
A conservative force, like gravity, can be represented by a potential energy. But in accounting for energy you either consider the work done by gravity or the change in gravitational PE. Not both!
Using gravitational PE: The agent does work on the system, increasing its energy. That energy is gravitational PE.
Using work done by gravity: The agent does work; gravity does negative work. There's no change in KE, since the net work is zero. (No concept of gravitational PE here.)
OK, I think I got it then. So, when considering an agent increasing the potential energy you disregard the work done by the conservative force, and when considering the work done by the conservative force, you take a look at how the kinetic energy changed.
Thanks for clarifying!
You are, of course, free to look at the change of kinetic energy whether or not you use gravitational PE. (In this example, it's zero no matter how you look at it.)
Its something like your income(work done by the applied external force) and bank deposit(gravity). When the object stays at rest before and after being lifted through a height h, its like your entire income had been invested in the bank; which you could later collect in the absence of income(increase in KE with only gravity pulling the object down). Recession effect! :smile:
Are you asking about the reaction of the Earth as the object is lifted? In the inertial frame of the object and the Earth, the center of mass of the object and the Earth is motionless. So m dx = - M dX.
Imagine a very large massive plate creating a constant gravitational field, and a very large charged plate creating a constant electrical field. The intensity of the fields are equivalent, such that an electron will move at constant velocity between the plates. Say the electron is moving at constant velocity away from the gravitational plate towards the charged plate. How much work is being peformed per unit time?
  • · Replies 54 ·
  • · Replies 27 ·
12K
  • · Replies 19 ·
  • · Replies 24 ·
