How Fast Does an Electron Move Between Capacitor Plates?
5 replies · 11K views · last reply
Boozehound
An electron is released from rest at the negative plate of a parallel plate capacitor. The charge per unit area on each plate is σ = 1.69E-7 C/m2, and the plates are separated by a distance of 1.72E-2 m. How fast is the electron moving just before it reaches the positive plate?
i started by using the equation E=σ/ϵ. so i got E=1.9096E4N/C. then i multiplied that by one coulomb to get force. so F=3.05536E-15N. i then took Newtons seconds law (F=ma) and found acceleration. for the mass of the electron i used 9.109E-31kg. so i was left with a=3.35E15m/s^2. i need to find out velocity, and so i looked for kinematic equations and i can't find one with all the variables that i have. it seems like everyone i try to use is missing 2 variables. am i overlooking something? please point me in the right direction. thanks!
You can use this equation again:
[tex]v^2 = v_o^2 + 2ax[/tex]
You have all of the values you need. Which ones are you unsure of?
I would try to equate difference in PE's with KE and forget kinematics entirely.
(edit: pretty much end up with Hages eqn either way)
As long as you've computed the acceleration, if you really want to use kinematics, use d=(1/2)*a*t^2 to compute the time and v=a*t to compute the final velocity. You have a superabundance of choices of how to complete the problem.
in response to hage567 i don't think that i have the initial velocity. thanks to all three of you.
"An electron is released from rest". Think again.
