How High Can an Object Reach if Projected Upward at 3.7 km/s?
The problem involves determining the maximum height an object can reach when projected upward from the Earth's surface at an initial speed of 3.7 km/s. The context includes concepts of gravitational potential energy and energy conservation principles.
  • Participants discuss using energy conservation equations to relate initial kinetic energy to gravitational potential energy at maximum height. There are attempts to manipulate the equations algebraically, with some participants expressing confusion over negative height results and the order of operations in calculations.
Multiple participants are actively engaging with the problem, offering suggestions for clarifying the algebraic steps and questioning the assumptions made in the calculations. Some guidance has been provided regarding potential errors in the equations used, but no consensus on a solution has been reached.
There are indications of confusion regarding the application of significant figures and the proper handling of units in calculations. Participants are also reflecting on the implications of the results in relation to the physical setup of the problem.
maniacp08
Gravity -- maximum height
An object is projected upward from the surface of the Earth with an initial speed of 3.7 km/s. Find the maximum height it reaches.
m
Ive used the Energy conservation
Kf + Uf = Ki + Ui
1/2 mvf^2 - G*M_e*m/rf = 1/2 mvi^2 - G*M_e*m/ri
= 0 - G*M_e*m/rf = 1/2 mvi^2 - G*M_e*m/R_e
R_e = radius of Earth = 6.37 x 10^6m
M_e = mass of Earth = 5.98 x 10^24kg
G = 6.67 x 10^-11 N*m^2/kg^2
1/radius_f = -Vi^2/2*G*M_e + 1/R_e
1/radius_f = (-3700 m/s)^2 / 2(6.67 x 10^-11)(5.98 x 10^24) + 1/6.37 x 10^6
=13690000 / 7.97732 x 10^13 + 1/6.37 x 10^6
1.716115187^-7 + 1.569858713^-7 = 3.2859739^-7
1/3.2859739^-7 = 3043237.806
then I do
3043237.806 - 6.37 x 10^6 but that gives me a negative height.
Can someone help me? I've been going at this problem for hours.
Sorry, but this is really hard to follow. I find it much easier to write out the whole problem algebraically before subbing in any numbers, and also using consistent significant figures.
If you could do this first it would help a lot.
This is the final equation:
then I solve for radius_f then I divide it by 1
then I subtract it from the Earth's radius to get the height but it gives me a negative height.
I'm not entirely sure why that is, but it could have something to do with order of operations (don't quote me on that). Using your formula, I would take a reciprocal of it first: [tex]R + r = \frac{2GM_e}{-v^2} + R[/tex]
From this we can see that the R terms cancel and we're left with r that we want to find. I have not solved this mathematically yet though.
well the textbook has the same problem explained but different velocity and it uses that equations and same steps I posted. But I don't know what I did wrong mathematically to give me a negative height. I was wondering if someone can work it out and see if they get the same answer or diff.
you go wrong right here: you forgot a minus sign in the first term on the rhs going from the 1st to 2nd line
m
Kf + Uf = Ki + Ui
then I do
Gravitational Potential is given by -GMm/r
So let u = GM so that
1/2mV2 - um/R = - um/(R + h)
V2/(2*u) = - 1/(R + h) + 1/R = h/(R2 +R*h)
You might recognize then in the near field with R >> h :
V2 = 2 * (u/(R2 +R*h)) * h ≈ 2*(g)*h
Rearranging:
2*u*h = V2R2 + V2*R*h
Solving for h then I get
h = V2R2/(2*u - V2*R)
Using km and u in km as ≈ 4*105 and R as 6400 km V as 3.7 km/s then ...
h = V^2R^2/(2*u - V^2*R)
h = 13.69 * 40960000 / (800000 - 87616)
h = 560742400 / 712384
h = 787.1350283 km
h = .7871350283 m
Do I add this to the Radius of the earth?
h = 787.1350283 km
h = .7871350283 m
The way it was originally constructed h was height above the radius.
Better check your conversion however. The bolded line looks OK. The one below - not.
And significant digits wise you should round likely to the nearest km.
The value of u for Earth for instance I already rounded.
See: http://en.wikipedia.org/wiki/Gravitational_constant#The_GM_product
  • · Replies 21 ·
12K
58K
