How is coefficient of performance different from efficiency?
Coefficient of Performance (COP) and efficiency both measure output relative to input, but COP can exceed 1 because it represents heat transfer rather than energy creation. In refrigeration, COP is defined as the heat removed divided by the work input, highlighting its role in moving heat rather than generating energy. While efficiency is limited to values less than or equal to 1, COP reflects the effectiveness of heat pumps and refrigerators in transferring heat. The distinction lies in terminology; COP is used because it can exceed 1, unlike efficiency. Understanding these concepts requires familiarity with thermodynamic principles and refrigerant cycles.
corona7w
Efficiency is essentially the ratio of what you get to what you put in. COP also seems to represents the same thing (i.e. COP of a refrigerator is Ql / W, which is the amount of heat removed / the amount of work done to remove it). I know efficiency cannot exceed 1, but how come COP can have values greater than 1?
Suggested Googling:
Heat pumps/engines
2nd Law of Thermodynamics
Carnot cycles.
The fridge isn't trying to create energy out of nothing,
just transfer it from one temperature to another.
COP is exactly the same thing as efficiency. (what you want/ what you pay for)
The only reason it isn't called efficiency is because it the coefficient can be higher than 1. You have to remember that the cycle isn't creating anything but shifting heat about.
That is basically the answer, however do read up on refrigerant/heat pump cycles. If you have a library available to you this stuff is in
Cengel and Boles - Thermodynamics. (University undergraduate level textbook)
  • · Replies 19 ·
  • · Replies 23 ·
10K
