How is EMF induced in a pendulum under the influence of Earth's magnetic field?
The discussion revolves around the induction of electromotive force (EMF) in a pendulum influenced by Earth's magnetic field. The problem involves a simple pendulum with a conducting wire and explores the relationship between the pendulum's motion and the induced EMF.
  • Participants discuss the calculation of magnetic flux and EMF, with various attempts to express the relationship between the pendulum's angle, area traversed, and induced EMF. Questions arise regarding the assumptions made about angular velocity and the nature of motion.
There is ongoing exploration of the maximum EMF produced during the pendulum's motion, with some participants questioning the validity of assuming constant angular velocity. Multiple interpretations of the relationship between angular displacement and EMF are being examined, and guidance has been offered regarding the time-dependent nature of the angular velocity.
Participants note that the problem may involve complexities due to the pendulum's harmonic motion and the varying nature of angular velocity, which complicates the calculation of EMF. There are references to the need for conservation of energy to find maximum values in the context of the pendulum's motion.
nishanth R
A simple pendulum with bob of mass m and conducting wire of length L swings under gravity through an angle 2 theta. The Earth's magnetic field component in the direction perpendicular to swing is B. The maximum potential difference induced across the pendulum is
MAGNETIC FLUX=BAcos theta
Area traversed by pendulum in 2 theta=theta * L^2
Magnetic flux=BA=B*Theta*L^2
EMF=d(B*Theta*L^2)/dt
=BL^2*d(theta)/dt
=BL^omega
=BL^2*(g/L)^1/2
But the answer is BL*sin (theta/2)*(gl)^1/2
Mgl(1-cosθ) = 1/2 ml2 ω2
Which gives ω= (2g(1-cosθ)/l)½
Which gives E = Bωl2 /2
E = Bl2sin(θ/2) (g/l)½
I think this is the maximum emf produced because when the pendulum rotates through an angle θ the area swept by it first decreases then increases again for the other half of the motion. Therefore the maximum emf would be produced when it sweeps through an angle θ.
You use ##\dot{\theta}=w## while ##\dot{\theta}## is something different here as pointed out earlier - we are not assuming uniform circular motion here remember.
Hey
Is my method right?
Ananya0107 said:
Hey
Is my method right?
You are right about there being a maximum emf, the original commenter assumes a constant ##\dot{\theta}## which is actually a function of time for the harmonic oscillator, the maximal value of this derivative depends on the initial angle of release as the first commenter pointed out.
But if I replace the area to be transversed as theta, then is my approach correct?
Area traversed by pendulum in theta=(theta * L^2)/2
Magnetic flux=BA=B*(Theta*L^2)/2
=(BL^2)/2*d(theta)/dt
=(BL^2)/2omega
=BL^2/2*(g/L)^1/2
Coffee_ said:
You use θ˙=w while θ˙ is something different here as pointed out earlier - we are not assuming uniform circular motion here rememb
I suppose omega is constant in pendulum motion. It is equal to (g/L)^1/2
##w## is indeed constant, but for a harmonic oscillator ##\dot{\theta}(t)## is not the same as ##w##. Remember that ##\theta(t)=Acos(wt+\phi)## and so the derivative is still a function of time and not constant. You are correct up to the point of ##EMF=\frac{BL^{2}}{2}\frac{d\theta}{dt}## from this point on you make a mistake. What you have to do is realize that EMF is a function of time because ##\frac{d\theta}{dt}## is also a function of time. So what you have to do now is find the maximal value of ##\frac{d\theta}{dt}## - easiest way to do so is to use conservation of energy from the initial position.
EDIT : To do so consider the relationship ##r\dot{\theta}=v## , and when v is maximal, ##\dot{\theta}## is maximal as well.
