How Is Entropy Calculated in an Isothermal Expansion of CH4 in a Carnot Engine?
The discussion revolves around calculating the entropy change during the isothermal expansion of methane (CH4) in a Carnot engine. The problem involves understanding the relationship between efficiency, temperature, and volume ratios in the context of thermodynamics.
  • Participants explore the connection between the Carnot cycle's efficiency and the temperatures involved. There are attempts to clarify the correct number of moles of methane and how it affects the entropy calculation. Questions arise regarding the relevance of maximum and minimum volumes in the isothermal process and the proper application of thermodynamic equations.
The discussion is active, with participants providing insights and questioning assumptions about the setup. Some guidance has been offered regarding the need to trace back to the start of the adiabatic expansion and the importance of sketching the cycle for clarity. Multiple interpretations of the problem are being explored.
There is confusion regarding the number of moles of methane and how it relates to the efficiency of the Carnot engine. Participants note that the initial volume is not at the isothermal expansion, which may affect the calculations. The problem constraints include the specific parameters of the Carnot cycle and the ideal gas behavior of methane.
A Carnot engine operates on 1 Kg of CH4, which we shall consider an ideal gas. Take \gamma=1.35. The ratio of max to min volume is 4 and the cycle efficency is 25%. Find the entropy increase during the isothermal expansion.
[Classical and Statistical Thermodynamics, Ashley H. Carter, pg.104]
dU = TdS-PdV
Ideal gas, isothermal expansion,\Rightarrow dU = 0
\Rightarrow dS=\frac{P}{T}dV=nR\frac{dV}{V}
\Rightarrow \DeltaS=R(62.5)ln(4)=720J/K
The correct answer is 294J/K
I know my problem has to be with the number of moles, probably accounting for the efficiency. working backwards I see there should be 25.5 moles of methane for n.
How do I account for the efficiency and get this answer?
In a Carnot cycle, the efficiency is connected to the temperatures of various processes. Does this help? Have you sketched out the cycle?
(Also, 1 kg methane is not 25.5 moles.)
\eta=1-\frac{T_{1}}{T_{2}}
Is that what you mean? How does that help for an isotherm? I'm not sure what information to use regarding the Carnot cycle itself considering the question only asks about the isothermal expansion.
For just the expansion with the ratio of volumes given my answer should be correct, there is some relevant information I am not seeing.
I know, its 62.5 moles. I got 25.5 from solving
nRln(\frac{V2}{V1})=294J/K
for n.
Sketch the cycle; are the volumes at the beginning and end of the isothermal process the maximum and minimum volumes in the cycle?
Thank you Mapes.
Of course those are not the max/min volumes. I was able to obtain the correct volume ratio buy utilizing PV^{\gamma}=constant for an an adiabat,\eta=1-\frac{T_1}{t_2}, and the given information.
I'm doing this question right now, and I am wondering how to get 294 J/K as an answer. I don't understand why the final volume doesn't relate to the max volume, and how to use PV^gamma to get the correct ratio.
Thanks.
Seem you guys forget that the initial volumn is not at the isothermal expansion, you have to trace it back to the start of adiabatic expansion then the isothermal expansion. (draw the diagram and you will see)
Ratio Max/Min volume is the volume at the tip of adiabatic expansion.
You'll need to use both PVg = PV/T = constant
Good brush up exercise though.
22K
9K
  • · Replies 21 ·
