How Is the Electric Field Intensity Calculated on a Charged Sphere's Surface?
33 replies · 5K views · last reply
gracy
The electric potential on the surface of a sphere of radius R and charge ##3##×##10^-6## is 500V.The intensity of electric field on the surface of the sphere (in N/C)is
##V##=##(\frac{1}{4πε0}\frac{q}{R})^2##
Actually I have solution but still I am unable to understand.So ,instead of my attempt at a solution .I 'll post solution itself.
##E##=##\frac{\left(\frac{1}{4πε0}\frac{q}{R}\right)^2}{\frac{q}{4πε0}}##
=##\frac{25×10^4}{27×10^3}##
=##\frac{250}{27}##
I want to how the above formula of E is derived.
BvU said:
Where did you get these squares ?
I didn't get you.
Diagram of a uniformly charged sphere of charge Q showing electric field E and potential V versus distance: E is zero inside, E = Q/(4πε₀R²) at surface R, falling as Q/(4πε₀r²) outside; V is constant Q/(4πε₀R) inside and falls as Q/(4πε₀r) outside.
Diagram of a uniformly charged sphere of charge Q with electric field E and potential V plotted below it: E is zero inside, peaks at Q/(4πε0R²) at the surface, and falls as Q/(4πε0r²) outside; V is constant Q/(4πε0R) inside and falls as Q/(4πε0r) outside.
Yeah, company politics forbid easy cut & paste. I uploaded the picture from the link. Which of course you studied extensively ...
You,king of sarcasm!
But actually I have studied it extensively before posting this thread(hyperphysics: this site is quite popular after wiki I usually refer this for physics along with physics classroom) ,but could not figure out/extract anything useful from it as you did!
Where did you get the square (as in the exponent being 2) in the above and in the following formulas?
=##\frac{250}{27}##
It has been given in the solution.
Gracy, the equation for the potential is wrong. You either copied it incorrectly or your book is wrong. You should know the potential formula for a charged sphere.
I copied it incorrectly.I know ##V##=##\frac{1}{4πε0r}## It was just by mistake.But I want to know about formula of E
I want to make sure there is square in the formula of E!
Sure. But by squaring ##q\over 4\pi\epsilon_0## you (or the 'solution writer') grabbed the wrong factor !
Check the dimensions too -- very helpful !
gracy said:
I don't know what is denominator in the formula of E?
According to his denominator is charge but how can this ##\frac{1}{4πε0}## be charge?
Electric field strength is Volt/meter, a.k.a. Newton/Coulomb
Yes. One and the same thing. Volts is Joule/Coulomb, Electric field is Newton/Coulomb and sure enough, Joule/meter = Newton !
Here denominator is coulomb means in formula there should be charge as denominator,right?
No. You also don't have a charge in the denominator of V and that is Joules/Coulomb !
Ever unraveled the dimension of ##\epsilon_0## ?
A very good place is this
Right. So does the dimension of V match your expectations ? And then: what's the difference with the dimension of E ?
Dimension for Voltage is ##ML^2T^3 I^-1## Dimension of E ##MLT^3I^-1##
Difference of one L (length).
I am still clueless about my question in op.
