How is the following fraction split for inverse Fourier?
The discussion focuses on the application of partial fraction decomposition in the context of inverse Fourier transforms. The user presents the equation X(w)=2/(-1+iw)(-2+iw)(-3+iw) and seeks clarification on how it is split into partial fractions. The correct decomposition is identified as X(w)=1/(-1+iw) + -2/(-2+iw) + 1/(-3+iw). Additionally, the user successfully splits another equation, 6/(2iw-3)^2(iw+1), and calculates the coefficients B=12/5 and C=6/12, while inquiring about the coefficient A using the cancellation method.
  • Understanding of inverse Fourier transforms
  • Familiarity with partial fraction decomposition
  • Basic knowledge of complex numbers and their properties
  • Experience with algebraic manipulation of rational functions
  • Study the method of partial fraction decomposition in detail
  • Learn about the properties of inverse Fourier transforms
  • Explore complex analysis techniques related to rational functions
  • Practice solving similar problems involving inverse Fourier transforms and partial fractions
Students and professionals in mathematics, engineering, and physics who are working with Fourier transforms and require a deeper understanding of partial fraction decomposition techniques.
Jeviah
Member advised to use the formatting template for all homework help requests
Hi i’m having problems with the following equations:
This then becomes the following equation according the the tutorial, although there is no explanation as to how:
X(w)=1/-1+iw, -2/-2+iw, +1/-3+iw
The commas indicated the end of each fraction to make it easier to interpret
This process is for inverse Fourier transform which i understand however to do not understand how the above step was completed
Use partial fractions.
Thank you i figured it out, although i have a problem with another question if you could possibly help out please
6/(2iw-3)^2(iw+1)
I have split it and obtained B=12/5 and C=6/12 with the layout A/(2iw-3), +B/(2iw-3)^2, +C/(iw+1) cancelling them out of the original equation to obtain the respective values
How would i obtain A considering using the cancellation method above, the denominator would equal 0
