How Long Does a Photon Think It Takes to Travel from the Sun to Earth?
  • Context: Undergrad
  • Thread starter Thread starter Canada Bob
    Photon Speed of light
The discussion revolves around the concept of how long a photon "thinks" it takes to travel from the Sun to Earth, exploring the implications of special relativity and the nature of time as experienced by particles traveling at the speed of light. Participants engage in theoretical reasoning, hypothetical scenarios, and clarifications regarding time measurement in different frames of reference.
  • Some participants assert that a photon does not experience time, suggesting that the concept of "elapsed time" is not applicable to it.
  • Others propose that the question of how long a photon takes is ill-defined, as a photon cannot possess a stopwatch or a rest frame.
  • A participant suggests using Lorentz transformations to analyze the situation from the perspective of an observer moving at relativistic speeds, indicating that time experienced by such an observer would differ from that perceived by someone at rest.
  • There is discussion about how an observer in a spaceship would perceive the travel time across the distance from the Sun to Earth, with considerations of length contraction and relative motion.
  • Some contributions emphasize that while the time experienced by a photon is not calculable, the time for an observer moving at a fraction of the speed of light can be determined using relativistic equations.
  • One participant expresses frustration at the complexity of the topic and the perceived lack of accessible explanations for laypersons.
  • Another participant highlights the importance of understanding established principles of special relativity before delving into more complex scenarios involving photons.
Participants generally agree that the concept of time for a photon is not meaningful and that the question itself may not be well-defined. However, there are competing views on how to approach the problem from the perspective of different observers, and the discussion remains unresolved regarding the implications of these perspectives.
Limitations include the challenge of defining a rest frame for a photon, the implications of length contraction, and the complexities of applying special relativity to hypothetical scenarios involving light-speed travel.
Canada Bob
I know that a photon traveling from the Sun takes around 8 minutes to get to Earth, but, how long does the photon "think" {if it had a stopwatch} it took to get from the Sun to Earth ?
zero. A particle traveling at c does not experience time irrespective of distance traveled.
I think a better way of putting this is that the concept of "elapsed time" does not apply to a photon. In other words, it's not that the answer to the question is "zero"; it's that the question itself is not well-defined, because a photon cannot have a "stopwatch" in the first place.
If you give us a Lorentz transformation which brings us to the rest frame of the photon, then we can bring a stopwatch and answer your question :P
OK, forget the photon, suppose a bloke in a "spaceship" {a bloke who owns an atomic stopwatch, or the like} zipped across 93 Million miles, how long would he think he'd traveled ?
That depends on how fast he is moving relative to us on earth. Remember that from his point of view, he is not moving at all; he's sitting in his spaceship while the Earth and sun are moving towards him. So as he is sitting there, first the sun passes by his window, and then a little later the Earth passes by. You're asking how long is "a little later" - just divide the distance between sun and Earth by the speed to get the answer. The only trick is that distance is not 93 million miles - that's what is for us at rest in the solar system, but the solar system is moving relative to him so he'll see a smaller distance because of length contraction.
Thanks for the above Nugatory, I'm with you on the first part, how "he" would see the sun go by and the Earth heading towards him, but, if I divide the distance by the speed of light I get around 8 minutes but that's from my point of view / my time scale, I'm not moving at the speed of light but the photon is, so the photon's time to cross that distance will be considerably much less than the 8 minutes that I perceive.
Well, again, the photon cannot measure time. But for astronaut "zippy" who is going at relativistic speeds the time can be much shorter than 8 minutes.
Appreciated, that the photons time will be different, but, "much" is a moveable feast, shouldn't it be calculable ?
'different' isn't the correct term, the correct term is 'does not apply'.
Yes. See posts 2 and 3.
If you're not satisfied with the correct answer, what kind of answer are you looking for?
If you mean time elapsed on a spaceship traveling at some fraction of c with respect to the Earth rest frame, use Lorentz transformations to get the length contraction of the Sun-Earth distance in the rest frame of the ship:
http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/tdil.html
Then divide the distance you get by the velocity of the ship to get the time elapsed.
As was mentioned before, V=c shouldn't be used in the calculations. Always use some fraction of c (it can be arbitrarily close to c, e.g. 0.9999999c).
May I suggest that, before you get buried even deeper into this, you read one of our FAQ entry?
https://www.physicsforums.com/threads/rest-frame-of-a-photon.511170/
Please note that our physics, including relativity, are meant to be used, and were formulated, for frames of reference in which c is always a constant and having the same value in all reference frame. Your question implicitly require that one can transform into a photon's frame where one if moving at the same speed as c (i.e. the speed of light is zero in that frame), thus violating all the rules that we currently have. Whether you believe that it can be done or not is a different matter, but what we KNOW is that our known physics are not meant for such a situation. That is why you got the type of response you received from PeterDonis. The situation you are asking for is unrealistic and has no answer, because the concept of "elapsed time" in a photon's rest frame is meaningless and has no formulation.
This is such a complex issue, even if you don't realize it, and especially when from what I can tell, you still don't have a good understanding of the more established part of Special Relativity. Don't you think it is prudent that you try and learn that first before delving into the more exotic aspect of the theory?
Zz.
Thanks for the above, particularly for the link, appreciated, the calculator on there resolves my curiosity.
Hello Zapper, I guess the "problem" is, we aren't all on the same rung of the ladder, or even on the same ladder {of interest}. I'm a retired marine engineer with a curiosity about certain elements of the cosmos. I had hoped that my question, presented in layman's terms, might have solicited an opportunity for someone to enlighten me in similar terminology rather than present some egotist the opportunity to show how vastly superior they are to folks.
When folks have approached me requesting my expertise I have never looked on them with disgust, disregard or disrespect, just because they don't know what I know.
I don't have an appetite or a need to do that, or a frail enough ego to seek to put people down.
If, as the sun passes the observer in the ship, he sends a flash of that light in the direction of the Earth that flash of light will reach the Earth before the Earth reaches the observer. The observer in the ship will find that the distance traveled by the light (which is considerably less than 93 million miles because of length contraction) divided by the time it takes for the light to reach the Earth (which is considerably less than eight minutes) is equal to the speed of light (of course).
Someone on Earth will interpret the same sequence of events as a flash of light being emitted from the ship as it passes the sun 93 million miles away; it takes the flash of light traveling at c eight minutes to cover the 93 million miles distance and reach the earth.
One interpretation uses clocks and distance measurements from a frame in which the Earth and sun are at rest, and the other uses clocks and distance measurements from a frame in which the ship is at rest. Neither interpretation tells us anything about "the photon's time" - that concept isn't even meaningful because we'd need a clock from a frame in which the photon is at rest to give us the photon's time, and there is no such frame because the thing is moving at the speed of light in all frames. (This is a slightly longer way of saying what haushofer said above. It's also an FAQ in the STEM learning section of this forum https://www.physicsforums.com/threads/rest-frame-of-a-photon.511170/).
I'm not sure where this came from. You appear to either have misread, or misinterpret the intention of the post. But more importantly, you are missing the LESSONS that you could have learned from it.
There's nothing wrong with asking the question. But in response, you also are being given a clear example here where, in physics, what you ask is often as important as the answer you are seeking. The question you are asking is similar to asking "when did you stop beating your wife?". It is based on a premise that hasn't been established to be correct.
When dealing with physics, this is an extremely important issue, because the terms we all use have very clear, and specific underlying formalism. Even "space" and "time" have clear and definite description. It is why I spent time trying to impress upon you that there is a reason why you are not getting a clear, straight-forward answer.
Unfortunately, it appears that my effort in trying to make you understand all this seems to be taken the wrong way. So I will not waste my time any longer.
Zz.
Thanks again Nugatory for your time and consideration, it's valued and appreciated.
Sure. Just use the Lorentz transform or the spacetime interval or even the simplified time dilation calculation. Whatever threshold you set as "much shorter than 8 minutes", there is some velocity which can be calculated and, if astronaut Zippy goes that fast, his recorded time will be "much shorter than 8 minutes". For example, if you say that "1 minute is much shorter than 8 minutes" then as long as Zippy goes .9922 c or higher then the measured time will be less than 1 minute.
Here is a little calculator for this:
http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/tdil.html#c2
EDIT: Oops, I see that Bandersnatch already posted the same calculator.
Well, I for one am certainly sorry if anything I said led you to think I am an egotist, or feel superior, or feel disgust, disregard or disrespect.
You could perhaps also ask what happens if you have a spaceship of mass M (at rest in some reference frame) and you impart it with kinetic energy E so that it passes through the two points A and B (also at rest). For an observer on the ship the passage from A to B will take a certain time T. Now, if you repeat the experiment so that everything is the same except that now the spaceship has less mass (so, specifically E and the distance between A and B are the same as before) then the observer would now measure a lower T.
If you repeat this argument and effectively let M go towards zero, then you would find that T also goes towards zero.
Perfect humor. Thanks for making me laugh out loud!
Although I think Zappers last paragraph was probably more than you wanted to hear, the thing is the paragraph above it was very informative and really gets to the heart of your question. To help out, let me point out this particular sentence:
"Please note that our physics, including relativity, are meant to be used, and were formulated, for frames of reference in which c is always a constant and having the same value in all reference frame. Your question implicitly require that one can transform into a photon's frame where one if moving at the same speed as c (i.e. the speed of light is zero in that frame), thus violating all the rules that we currently have. "
What this means in layman's terms is that whatever speed you are going, as long as it's less than c, you will always find that the speed of light is also c. If you were to actually go c (if you were a photon), then this rule would no longer apply. In other words, if you were in a spaceship and it was going c (impossible) then a beam of light would be standing still (also impossible) so you can't ask a question like this because it is not a logical question to ask since light cannot stand still. It's fine to imagine what it would be like, but it's the same thing as imagining if the person you see in the mirror is a person from another dimension. Fun to think about, but that's all. However, I might add (but don't take this as the gospel since I don't really know if it's a sensible answer) but my take on this is that since a photon never expires, one could say that its time has stopped for all eternity. (that might be more of a philosophical answer than a real one, but it's juicy to think about). Hope that helps. (And I hope I interpreted Zapper's answer correctly)
Yes, one can say that "a photon's time is stopped for all eternity". But one can also say "The gostaks distim the doshes". Unless there's such a thing as "a photon's time" the former statement is as meaningless as the latter.
Around here, when we say "the time of <something>", we mean time as measured in a frame in which that <something> is at rest. If you want to invent a different definition so that you can say something meaningful about "a photon's time" you're free to do so - but not at Physics Forums, please!
As the original question has been answered, we can close this thread.
  • · Replies 25 ·
  • · Replies 33 ·
  • · Replies 18 ·
  • · Replies 57 ·
  • · Replies 90 ·
  • · Replies 19 ·
  • · Replies 32 ·
