How Long Does It Take a Block to Slide Down a Frictional Incline?
The discussion revolves around a physics problem involving a block of ice sliding down a frictional incline. The specific scenario includes a 10 kg block on a 20 m ramp inclined at 10 degrees, with questions about acceleration on a frictionless ramp and the time taken to slide down with kinetic friction present.
  • Mixed
  • Participants discuss the forces acting on the block, including weight, normal force, and friction. There are attempts to set up equations for the forces in both the x and y directions, with some participants questioning the presence and calculation of friction.
Participants are actively engaging with the problem, sharing their calculations and reasoning. There is a collaborative effort to clarify the forces involved and how to approach finding the time taken for the block to slide down the ramp. Some guidance has been provided regarding the use of free body diagrams and kinematic equations.
There is mention of a coefficient of kinetic friction and the need to consider both frictional and gravitational forces in the calculations. Participants express uncertainty about certain aspects of the problem, particularly regarding the forces in the y-direction.
jord12321
Need help with Incline Plane Problem!
A 10 kg block of ice slides down a ramp 20 m long, inclined at 10 degrees to the horizontal.
a) If the ramp is frictionless, what is the acceleration of the block of ice? (I was able to do this question the answer is 1.7 m/s²)
b) If the coefficient of kinetic friction is .10, how long will it take the block to slide down the ramp, if it starts from rest?
So right now I know I have...
m= 10 kg
d= 20 m
sin10
cos10
v1= 0 m/s
a= 1.7 m/s²
I'm really not sure what to do.
I'm not sure what to do, I need to know where to start!
m= 10 kg
d= 20 m
sin10
cos10
v1= 0 m/s
a= 1.7 m/s²
To start with, you should probably draw a FBD of the block on the ramp. :smile:
Ok i did that, I just don't know what to solve for first.
Alright, so you drew your FBD.
You have a Weight force going down.
A normal force going perpendicular to the ramp's surface.
A friction force going the opposite direction of motion.
Correct?
Now... 2 questions for you.
\SigmaF_{y}= ?
\SigmaF_{x}= ?
correct,
fx = sin10mg = sin10 x 10 x 9.8 = 17
fy = cos10mg = cos10 x 10 x 9.8 = 96
Where is your friction force? I can't tell if you have one or not.
What do you mean? Didn't i just solve for parallel and perpendicular force?
I might be missing something myself; running on very little sleep here. Sorry.
I don't have the force of friction yet.
I was able to get friction because fn = f perpendicular. So i did .10 x 96 and got friction to equal -9.6
Ok, so after looking at this myself...
I get.
\SigmaF_{x}=mg*sin\Theta - \mumg*cos\Theta
I'm still working on Fy.
Ok, thanks for your help!
Friction = \mumg*cos\Theta
The reasoning:
N = -mg*cos\Theta
So, friction = -.10*98*cos(10) = -9.65 N
Correct?You're welcome, but I don't know how much help I was. :/ Fy always gets me in these problems.
The reasoning:
N = -mg*cos\Theta
Correct?
I got the same answer as you.
Right. And you can find acceleration from there, correct?
Correct, but I'm suppose to find time.
Then you use the acceleration and plug it into a kinematic equation.
You have delta x, acceleration, and an initial velocity.
So, you have to find your time using...
\Deltax = V_{i}t + 1/2(a)(t^{2})
Please correct me if I'm wrong.
You are right! Thank you so much for helping!
You're very welcome!
  • · Replies 27 ·
10K
  • · Replies 33 ·
