How long will a lc tank circuit oscillate after power is removed?
The discussion focuses on determining the oscillation duration of an LC resonant tank circuit after power removal. Given parameters include an inductance (L) of 1 henry, a resistance of 500 ohms, and a capacitance (C) of 50 picofarads, resulting in a resonant frequency (Fres) of 22,507 Hz. The oscillation decays exponentially, with the time constant calculated as 2Q/frequency, where Q is the quality factor derived from circuit losses. The quality factor can be calculated using the specified resistance as the only dissipative loss in the ideal circuit.
  • Understanding of LC circuits and their components (inductance, capacitance, resistance)
  • Knowledge of the quality factor (Q) and its significance in oscillatory systems
  • Familiarity with exponential decay in oscillations
  • Basic mathematical skills for calculating resonant frequency and time constants
  • Research the calculation of the quality factor (Q) in resonant circuits
  • Learn about the implications of damping in LC circuits
  • Explore the mathematical derivation of oscillation decay rates
  • Study practical applications of LC tank circuits in electronics
Electronics engineers, physics students, and hobbyists interested in understanding the behavior of LC circuits and their oscillation characteristics.
hobbs125
If a lc resonant tank circuit is disconnected from power how do you determine the length of time it will oscillate.
L=1 henry, 500 ohms
C=50pf
Fres=22,507 hz
It will decay exponentially. Usually you specify the time it takes to reach a certain ratio of the maximum (usually 1/e or about 36%), since mathematically the amplitude of oscillations will never reach zero.
Ok, so how would I calculate that?
The time constant is 2Q/frequency; where Q is the quality factor of the circuit.
In order to calculate Q you need to know the losses in the circuit; if the above values are for an ideal circuit (meaning the 500 ohms are the only dissipate losses in the circuit) them you can calculate Q from them (google Q factor)
Awesome, thank you.
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 41 ·
