How many triangles can you form with 21 evenly distributed dots?
  • Thread starter Thread starter davee123
    Triangles
The discussion revolves around a challenging mathematical problem involving the formation of triangles from 21 dots arranged in an equilateral triangular pattern. Participants debate the interpretation of the question, specifically whether to consider only equilateral triangles or all types of triangles. Calculations reveal differing results for the number of equilateral triangles, with some participants noting the importance of considering non-standard orientations. The conversation also touches on the complexity of identifying valid triangles, as combinations of three collinear dots do not form valid triangles. One participant calculates that there are 1216 valid triangles after accounting for 114 degenerate cases. The group expresses interest in finding a general formula for the number of degenerate triangles and discusses the potential for algorithms to simplify the problem-solving process.
davee123
So, being inundated with the "How many triangles?" questions on Facebook, I noticed this one which is actually more difficult than I expect the question author intended:
http://creative.ak.facebook.com/ads3/flyers/36/28/6002237517496_1_992e4bd8.jpg
Assuming you have 21 dots evenly distributed in an equilateral triangular pattern (like bowling pins), how many distinct triangles can be formed by connecting the dots?
Of course, I'll bet they expect people to interpret "equilateral triangles" rather than simply "triangles", but it does make for a more interesting challenge.
And on that note, how many are possible with 3 dots, 6 dots, 10 dots, and 15 dots? Is there a nice formula for progression as the number of available dots increases?
DaveE
When the "starting triangle's base" has N dots, then the number of equilateral triangles is
(N-1)*N*(N+1)*(N+2)/24
which means
70
equilateral triangles in the figure.
:smile:
Which way do you want us to interpret it: only equilaterals or all triangles?
I suppose both questions are interesting-- answer what you will, I guess! But I couldn't think of a formula that expressed the number of "triangles" given N dots. I honestly never even tried to answer the equilateral triangle question, since it seemed more trivial. But there are some interesting caveats to it.
DaveE
I get a different answer from rogerio for equilateral triangles. Maybe I am overlooking some triangles somewhere...
For N even:
n(2n^2-n-2)/8 = 48 triangles for n=6 base dots
For N odd:
(n-1)(n+1)(2n-1)/8 triangles.
I got the same answer as Rogerio for the equilateral triangles-- there are some non-standard orientations, don't forget!
DaveE
DaveE
Oops, yes! I was missing those.
I'm assuming your formulae simply count all possible 3-dot combinations and assumes a triangle joins them. Is that correct?
Do these formula eliminate "degenerate shapes"? i.e. three dots in a straight line does not a triangle make, so some combos of 3 dots are not valid.
Oh, I see you guys are pursing only equilateral triangles so far, so my point is moot.
Well, moot in terms of equilateral triangles, but not all triangles, which is what I was more interested in. Figuring out all the sets of 3 points is pretty simple, but figuring out which sets of 3 are in straight lines was tougher-- at least in terms of trying to get a formula.
DaveE
DaveE
I suppose it would be easier to write an algorithm (where you have access to loops and decision trees) than a formula. I wonder if all algorithms are transposable into formulae...
Agreed.
I got 114 degenerated triangles (3 points in line).
So the number of general triangles in the figure is
21*20*19/6 - 114 = 1216.
But it was a very ugly way...
Yep, that matches what I got, although I just did 21 choose 3 - 114. Same difference, though.
DaveE
General formula for the 114? Now that should be fun!
