How Many Ways to Split Students and Combine Outfits?
  • Thread starter Thread starter Apophis
    Permutations
The discussion focuses on solving two combinatorial problems involving students and outfit combinations. For the first problem, the task is to determine how many ways twelve students can be split into three groups of five, four, and three, using the combination formula. The second problem involves calculating the total outfit combinations from six pairs of jeans, three shirts, and two pairs of sandals, resulting in 36 different outfits. The calculations for both problems are clarified, leading to a better understanding of combinations and permutations. The thread concludes with appreciation for the assistance received.
Apophis
:rolleyes: I can normally do combinations and permutations, but these two currently stump me. Any help is appreciated. :confused:
1) Twelve students are in a class. They are split so that five go to room A, four go to room B and three go to room C. How many different ways can this happen?
2) You have six pairs of jeans, three shirts and two pairs of sandals. How many different outfits can you wear from these choices?
:rolleyes:
Mathematics news on Phys.org
For number two, I think (2c1)(3c1)(6c1) describes the correct answer. There are 36 combinations. Thats evaluated as
nCk = \frac{n!}{k!(n-k)!}
For The First One:
(12C_5)(7C_4)(3C_3)
For The Second One:
Take One Shirt ===> You can pair it up with 6 different jeans
And each of the above pair of shirt+jeans can be worn in two way (with 2 different pairs of sandals) Therefore total cases=
(1 x 6) x 2 =12
Similarily the above case happenes 3 times for three different shirts :
12 x 3
Ans= 36
Thank You
Thank You all for the help. This makes more sense to me now. :biggrin:
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
