How much force is used to pull the block?
  • Thread starter Thread starter Dillion
    Block Force Pull
The discussion revolves around calculating the force required to move a 7 kg block on a flat surface, transitioning from an initial velocity of 2 m/s to a final velocity of 4 m/s over a distance of 5 m. The coefficient of friction is given as 1. The net force calculated was 8.4 N, leading to the conclusion that the pulling force must exceed the frictional force of 68.6 N, resulting in a total pulling force of 77 N to achieve the desired acceleration.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of kinematic equations for motion
  • Familiarity with the concept of friction and its calculation
  • Basic understanding of forces and net force in physics
  • Study the derivation and application of Newton's Second Law in various contexts
  • Explore kinematic equations in-depth, particularly vf^2 = vi^2 + 2a(change in x)
  • Learn about the different types of friction and their coefficients
  • Investigate the relationship between net force, frictional force, and applied force in dynamic systems
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of forces, motion, and friction in practical scenarios.
Dillion
A 7 kg block on a flat surface moves from 2 m/s to 4 m/s over 5 m. The coefficient of friction between the block and the surface is 1. How much force was used to move the block?
Honestly, my physics instructor gave us so many worksheets with so many worksheets, I have no clue which one to use.
4^2 = 2^2 + 2a(5)
a=1.2
F=ma
F = 7*1.2
F=8.4
I don't know how friction comes into play though...Thank you!
Dillion said:
F=ma
In that equation, what exactly does F represent? Be precise.
Net force..?
Dillion said:
Net force..?
Yes. What actual horizontal forces are present here?
Dillion,think for a minute would you
The net acceleration is 1.2 m/s^2
This acceleration can be yielded by applying a force F to the block which acts in the forward direction,opposing the frictional force(acting in the opposite direction)
i am sorry for posting a complete solution
It's just that you know I couldn't help myself
Please delete it now or I will have to report it.
Ummm okay
I will
i edited it
Is it okay?
UchihaClan13 said:
i edited it
Is it okay?
Yes , that's fine, thanks.
You're welcome
Force of friction = coefficient of friction * normal force
Force of friction = 1 * 7
And the pulling force
Yes.
No. You should show units. A force is not just a number. If you fill in the units you might realize you have forgotten something.
Yes.
So how do these three relate: the frictional force, the pulling force, the net force that you calculated?
haruspex said:
Yes.
Yes.
Ohhh it should be 1 *68.6 (7 * 9.8 = normal force). So the force of friction is 68.6.
"So how do these three relate: the frictional force, the pulling force, the net force you calculated?"
The net force is equal to 0 when the block is not moving. So the pulling force has to be more than 68.6, correct?
Yes, but you still need to mention the units. How much more?
68.6 Newtons. I don't know how to calculate how much more...
You calculated the frictional force as 68.6N. Let the pulling force be FP. Do those act in the same direction or in opposite directions? What is the net of those two forces?
The Frictional Force is -68.6N and the pulling force is positive N. The net force is 0?
You calculated the net force in your first post in this thread. It wasn't zero. If the net force were zero there'd be no acceleration.
The net force was equal to 8.4 N.
Frictional force (-68.6N) plus pulling force = 8.4 N.
Is the pulling force 77N?!
Yes.
Yes it's 77 N!
You're correct!
UchihaClan13
  • · Replies 33 ·
  • · Replies 45 ·
