How much lower would a sheep be expected to jump if on a steep upward slope?
  • Context: High School
  • Thread starter Thread starter questions8938
The discussion revolves around the expected jumping ability of sheep when faced with a steep upward slope, specifically in the context of constructing a barrier to keep them off a property. Participants explore the implications of slope on jumping height, the effectiveness of different barrier designs, and the practical considerations of using natural materials.
  • Some participants suggest that the average jumping height of sheep is around 90cm, with a recommended fence height of 120cm, but question how this would be affected by a 1M steep bank.
  • There is uncertainty about the definition of a "1M steep bank" and its implications for the slope's steepness and horizontal distance.
  • Some argue that estimating sheep jumping ability on a slope is complicated due to the biomechanics of jumping and animal psychology.
  • A participant proposes that digging a ring ditch could effectively increase the height of the barrier while reducing the amount of wood needed.
  • Others mention that sheep may not like to enter ditches, which could affect the design of the barrier.
  • There are discussions about the potential for sheep to learn from each other, affecting their behavior around barriers.
  • Some participants question whether the slope truly matters if the sheep approach the fence from a perpendicular angle.
  • A participant mentions that the fence design could be minimal, consisting of tight horizontal wires, to prevent sheep from cresting the slope.
Participants do not reach a consensus on how much lower a sheep would be expected to jump on a slope, with multiple competing views on the effectiveness of various barrier designs and the factors influencing sheep behavior.
There are limitations in the discussion regarding the assumptions made about sheep behavior, the definitions of slope measurements, and the complexity of predicting jumping ability based on various factors.
questions8938
TL;DR
Jumping sheep
I mean jumping upwards - ran out of characters in the title.
I am wanting to make a barrier out of natural materials to keep sheep off my property.
The wood material for a barrier at the top of the bank is limited which is why I want to use the least wood I can get away with, so lowest fence at the top which would stop them, while having the soil bank do most of the work as I have no limit of soil, within reason.
I tried looking up searches like 'jumping uphill' and got absolutely no useful information, just generic jumping articles.
If a sheep is said to jump on average about 90cm, with 120cm being the recommended minimum height for official wire fencing, then how much would that be expected to be impeded if they were inclined on a 1M steep bank? The 1M height is arbitrary but that is about the height I have done so far and seems a good round height to choose. That height is a good amount as well in terms of work vs result as I have to think of how long it will take and how much effort will be involved.
Thinking about it, despite their formidable jumping capabilities, I could not imagine them being about to jump uphill much if at all if their hooves are already up the slope? Any guesses on this for how low I could put the fence at the top? No fence would not work because I know they are good climbers and scramble around steep hills so they could just walk up and over. The bank will not be totally sheer, due to dirt falling back down; I would guess about a 60 degree slope.
I would just have to make sure there is not a platform up the top so they could right themselves again shouldn't I but even if there was they would still be disadvantaged so long as it wasn't a big enough shelf that they could get a normal footing again to be square on to the fence, right? So perhaps as low as them not just able to step over, perhaps even just above the legs? If I prevented a shelf or even put the fence jutting out at 45 degrees to the slope it could be even lower couldn't it? Like how they do with spikes on buildings to stop birds landing on them.
So any scientific guesses and what forces are at play acting on the sheep on a slope?
Personally I know from when going on walks if I am on a slope I could not imagine jumping up the hill more than a couple of paltry cms but not sure how much better a four legged creature would do.
questions8938 said:
.. 1M steep bank? The 1M height...
What is a "1M steep bank"? 1m height difference (rise) over which horizontal distance (run)?
questions8938 said:
So any scientific guesses ...
Let me tell you right away: As soon as living organisms are involved, rough scientific guesses and estimates (based on spherical sheep) will spread so wide, that they are practically useless for your real world application. Aside from the complex bio-mechanics of jumping, you have the whole animal psychology issue.
I guess you are american and bank is an english term? Bank just means slope. What difference does the run make if it is 1 meter or 100? The facing that the sheep would confront would be the same no matter the distance, they can only walk up one section at a time. It is a ditch dug into the ground with the soil dug flung into a pile to form a 'bank'/slope.
So I should just give up? You don't think humans have been doing this for hundreds if not thousands of years already to stay alive? These are traditional techniques.
You misunderstand the question. 1 m is a measure of height, not steepness. The question is, over what horizontal distance does the height change by 1 m?
It means the same.
A 1:100 slope would be a lot easier to scale than a 2:1 slope.
He specifically said "scientific guesses" are useless.
Learning from experts is a better way.
Trial and error is another way.
Is there some reason why you can't dig a ring ditch? You could double its effective height (or halve the work) if you pile the excavated dirt on the high side.
Apparently sheep don't like to go into ditches - even small ones.
I know what "bank" means, but not what "1M steep" means.
Predicting how high exactly sheep can jump on a slope using physics? No, I don't think humans have been doing this for hundreds or thousands of years already.
They rather used trial and error, or experience of others, which is your best option. There should be many people in the world building sheep fences on a slope.
questions8938, welcome to PF.
You say they will jump, then you ask "how high"?
Don't give up.
It will depend on the type of sheep, where the feed is, and how well self-trained they are. One old and clever sheep, will teach all the others, and then the next generation.
The old agricultural technology, a dry moat, is called an "haha".
Slope is downwards, to a vertical wall up. The field beyond the garden appears to be joined, because there is no fence or wall visible in the landscape.
https://en.wikipedia.org/wiki/Ha-ha
I have 50 sheep here this month, and they will "parkour" their way up concave bends in walls.
It's not always an old one!
It depends whether the sheep have perfected the Fosbury Flop.
The simplest calculation would be to add to 1.2m the change in height of the center of mass of the sheep (a negative number). I have no idea how accurate it would be.
Did you ever consider a HaHa? ( credit to @Balucore)
If you have only limited wood but a bit of land to work with (+ loads of energy). You get double the use out of every spadeful because it comes out after the hole and up the bank.
I don't know tif that would work for goats, though. They have the next best thing to Levitation.
Does the slope really matter? What if the sheep is moving perpendicular to the fall line when they get to the fence?
What is a fall line?
Kind of like Paul Newman
I believe you mean Steve McQueen
  • Agree
The direction of maximum slope (minimum? IDK). Arg(-grad(h))=0 where h is the height of the ground. If you're a nerd.
Downhill. If you're a skier.
Oops, thanks!! :smile:
A sheep can climb up a wall with an 80° batter. The aim should be to cap the wall with a low vertical fence that will prevent the sheep from cresting the slope. The fence only needs to be made from a few tight horizontal wires to prevent sheep getting through. Close-space the wires at the bottom of the fence, to prevent sheep pushing through, but you can place the wires further apart at height.
The equivalent fortification technology is the "glacis", which is the ramp at the foot of a castle wall. A glacis is usually steeper than 45°. They are made to be like an icy surface, so the invaders will slide off, and cannot foot a ladder, or scaffolding, near the wall.
https://en.wikipedia.org/wiki/Glacis
A vertical haha wall, if it is high enough, maybe 1.5m, (5'), may not need a fence at the crest, while a normal height stock fence will be needed for a natural slope angle of less than about 15°.
Consider the glacis and the crest-fence as a single structure. Measure the height of the fence from a point one sheep length, say 500mm, (20"), back from the foot of the fence on the crest. In my experience, if that is greater than about 1.2m, (4'), the sheep will be dissuaded from attempting the jump. I am not saying it is impossible, just most unlikely, but something they might learn if being chased downhill towards the structure. Unlike pigs, sheep can fly for short distances, such as over stock grids in roads.
Why is a glacis like a lazy dog.
Because it is a slow pup.
Right. So why would that matter? I mean, yes in the extreme cases it would make a different challenge, but what does it have to do practically with a sheep appoaching it?
Obvs, any solution that lets the sheep scale the slope (say, by leveraging an edge condition) fails, but that seems to go without saying.
Great. What is a batter?
(I can guess, but I think it's apparent this is a niche science and I am not ... nichey enough.)
I think the point is that the OP is hoping that a slope before the final wall will enable him to make the wall shorter. But if the sheep runs alongside the wall at the top of the slope and jumps, it will be able to jump just as high as if it were on level ground (modulo one leg being farther down the slope than the other, but not by much if their hooves are close together against the wall).
I'd never say never but would a sheep have the sense to run / accelerate along a contour line and then do a sharp left and an immediate jump? That would require a long downhill stretch of one leg to push off with in the right direction (vectors). Let's face it, sheep are the dopiest of all farm animals and not suited to track and field events. Hope I'm not treading on any sheep-loving toes here.
It would have to be a slow, climbing action to get over the final height of fence. If the fence is picket style, with vertical logs, maybe just 1m, climbing would be hard. (But maybe not for a canny goat. - not a nanny goat))
You silverbacks are so elitist! :wink:
The smartest evidence for sheep intelligence was seen when walking in Wales. (Sheep and moorland). A flock of sheep on a nearby hillside started to panic when we whistled at them. They were looking round for a farmer and his sheepdog; they don't like sheepdogs too much.
Because quick brown foxes jump over it?
Sheep can, without trying, easily do 3 metres in the long jump. Chickens are more stupid than sheep. If you have not worked with sheep, then you will not have seen what they can do, or realised how well organised they are. The leaders understand human verbal commands, and work with sheepdogs, not against them. When I call and command imaginary dogs, the sheep interpret my commands and move as they would if dogs were present. Sheep are better behaved and more relaxed when I do not use real dogs.
There is a whole social network in a flock. Some sheep are watchers who will raise an alarm, others are defenders who will face the threat and actively defend the flock, so don't stress the sheep and then turn your back on them.
In any flock there will be a couple of rogues, who will test fences and gates, then teach the other sheep their tricks. The rogues know the grass is always greener on the other side of the fence. Those sheep will run at a fence and try to leap it, they will climb walls, and squeeze through wire fences.
Sheep really only need fodder, and some bucolic peace and quiet. They are quite intelligent, but it is usually not recognised by people who think they all look the same.
Note to self: Million dollar business idea. Grooming and boarding services for imaginary sheepdogs. Overhead costs: zero!
  • Haha
12K
  • · Replies 17 ·
  • · Replies 17 ·
