How much weight required to submerge this object?
The discussion revolves around the requirements for submerging a 2000L plastic tank using weights in a film production context. Participants explore the principles of buoyancy, water displacement, and mechanical advantage related to pulleys and weight distribution.
  • One participant describes the setup involving a 2000L plastic tank and 3000kg of steel weights, questioning if this weight is sufficient to submerge the tank.
  • Another participant mentions the mechanical advantage of pulleys, suggesting that a pulley system could allow for lifting twice the weight of the pulling force.
  • A participant expresses uncertainty about the application of the 2:1 principle in their specific setup, questioning the effect of the pulley’s orientation on the required weight.
  • Concerns are raised about the speed of the tank's submersion, with a participant advising against using techniques that might cause the tank to rise unexpectedly.
  • A question is posed regarding the use of steel drums filled with water as weights, leading to a discussion about the actual underwater weight being only that of the steel.
  • Another participant confirms that using water-filled drums does not provide any additional advantage for underwater weight.
Participants express varying levels of confidence about the weight required to submerge the tank and the effectiveness of different methods. There is no consensus on the optimal approach or the sufficiency of the weight described.
Participants discuss the principles of buoyancy and mechanical advantage, but there are unresolved assumptions regarding the specific setup and conditions of the submersion process.
Individuals interested in practical applications of physics in film production, particularly those dealing with underwater mechanics and weight distribution.
backsdraw
Hi all,
So A quick question for all the smart minds out there to ponder (plus I'm stumped and need help).
I'm helping a friend out with a short film and we are trying to be cost efficient.
I need to submerge a 2000L plastic tank (circular and approx 1.5 high) and then release it to make it look like it's popping out from the ocean.
The tank we have is 3 metres deep and we have 3000kg of steel weights which we have a friend making a low profile steel rack for stacking the weight and to attach pulleys.
We will run a line from the tank through the pully attached to the weight stack and back to a forklift to pull the tank under.
Or we get a turfer and do a direct pull from the weight stack.
I slightly understand the principle of water displacement and realize that the steel will weigh less under water due to it's volume/water displaced.
A rough guesstimate would be 600L of displacement so the weights will be approx 2400kg or 2.4 ton underwater.
I know this weighs more then the object we are trying to submerge so excuse the silly question...but is that enough weight firstly to pull the tank directly down with the turfer...
Or if we go with the pulley and forklift method, because it's 2 forces from above, does the weight at the bottom need to be doubled?
Hope you can understand my explanation and thanks for any help.
Backsdraw
As long as the pulley doesn't jam, you should be okay. You're remembering the mechanical advantage of two pulleys from way back in school giving you an ability to lift twice the weight of the actual pulling force.
Thanks Bystander...so I'm thinking of the 2:1 principle or something like that... but it doesn't apply in this situation because it's a single pulley purely to enable pull from another direction? (so essentially the pulley isn't there and I'm just pulling a direct weight).
If this is correct, would it not matter at all where the pull once through the pulley was from then? ie...directly above, directly to the side, 45 degrees etc etc...I assume it doesn't but just checking...
For some reason known to only my brain, I still think I don't have enough weight on the bottom but that's all I can get!
You don't want to hook up to the people who drive in tractor pulls, or the weight will come off the bottom just because your tank won't sink quickly enough, but a nice slow sedate drawdown in quiet water should be very well behaved.
Haha...I'll be the calm driver...thanks again.
And just one more question...what happens if you use steel 44 gallon drums filled with water for weights...since the volume is the same as the weight, does this just completely cancel it out and the actual underwater weight is only the steel or is there some other calculation for this scenario?
No magical advantage --- that's why novelists always fill oil drums with cement to dispose of victims.
Aha...so it's pointless to use a water filled drum as an underwater weight...cheers
  • · Replies 22 ·
  • · Replies 35 ·
  • · Replies 24 ·
47K
