How not to get stuck up with one approach?
  • Thread starter Thread starter n.karthick
    Approach Stuck
The discussion centers on the challenge of sticking to ineffective methods despite awareness of alternative approaches. The original poster expresses a tendency to persist with their current strategy, driven by a desire not to give up, which often leads to wasted time and resources. They question whether this behavior is psychological and seek advice on adapting to situations without stubbornness. Responses suggest that ego and pride play significant roles in this persistence, emphasizing the importance of humility and acceptance of failure. Recommendations include adopting a mindset that allows for flexibility, acknowledging past failures, and considering alternative methods without self-imposed pressure. Techniques like exercise, meditation, and seeking professional help are also mentioned as potential aids in overcoming this issue.
n.karthick
Hi,
I am used to do things independently in my life and rarely takes the advice of others. The one important problem I often face is, whenever I try a method i always stick to it even if it doesn't work. I try to fight with the same approach to find solution to the problem in hand. Though I am aware of alternate approaches, I can't make my mind to drop the present approach. Something inside me says "why not try little more harder and don't give up". So I often waste time and resources end up in failures (though few times my persistence paid me back heavily). Is it a psychological problem? How can I change myself to adapt to the situation and not being stubborn.
If you see of alternative approach, that seems faster and efficient, then just tell to yourself that the alternative approach too is your own approach. You don't need to walk to your office when you have already earned a car.
But, if the alternative approach is walking to your office, and the main approach is driving to it and the problem is car not starting, then it all depends upon how much free you are and how important is office.
I myself fall on such situations occasionally.
The reason why we get stuck on our approach is that, if we are able to repair the car, then it would be beneficial for future too. Walking is one time solution.
n.karthick said:
Hi,
I'd suggest exercise, meditation, no coffee, and good shrink. Otherwise, this always works for me:
When in trouble,
When in doubt,
Run in circles,
Scream and shout!
it's an ego problem. you have to let go of your pride.
That is a good method.
Don't put high demand on yourself. Indeed believe that you aren't the smartest of the person. If you were you would have already solved it far back. So, you need to take a step back and not be stubborn.
Say to yourself "Hmm! I tried that way but failed. So, I have to go this way"
You need to accept that you failed. You indeed did fail. So, you need to acknowledge the truth and moveone.
:) (Just Thinking out loud)
Similar to the 2024 thread, here I start the 2025 thread. As always it is getting increasingly difficult to predict, so I will make a list based on other article predictions. You can also leave your prediction here. Here are the predictions of 2024 that did not make it: Peter Shor, David Deutsch and all the rest of the quantum computing community (various sources) Pablo Jarrillo Herrero, Allan McDonald and Rafi Bistritzer for magic angle in twisted graphene (various sources) Christoph...
Thread 'My experience as a hostage'
I believe it was the summer of 2001 that I made a trip to Peru for my work. I was a private contractor doing automation engineering and programming for various companies, including Frito Lay. Frito had purchased a snack food plant near Lima, Peru, and sent me down to oversee the upgrades to the systems and the startup. Peru was still suffering the ills of a recent civil war and I knew it was dicey, but the money was too good to pass up. It was a long trip to Lima; about 14 hours of airtime...
