How thick should a steel plate be to support a load of 1300 N in a 3 point bend?
To support a load of 1300 N in a 3-point bend on a steel plate measuring 420 x 630 mm, the initial calculation suggested a thickness of 15 mm, which seemed excessive. The correct Young's modulus for steel should be used in MPa, leading to a recalculated thickness of approximately 3.8 mm. It's important to ensure unit consistency in calculations to avoid errors. Using structural analysis tools like BeamCALC can help verify results. Accurate calculations are crucial for ensuring the structural integrity of the design.
Grant_
I'm using the basic deflection equation to determine how thick a plate of steel would have to be to support a load of approximately 1300 N in a 3 point bend, with surface dimensions of of 420 x 630 mm.
I = bh3/12; δ = FL3/(C1EI); Esteel = 200 GPa = 200 N/mm; δ = 50 mm (arbitrary);
h3 = 1300*(4203)*12/(48*50*630*200)
I'm getting a result of 15 mm... to me that seems a bit thick, especially when the weight would be close to 33 kg. Am I missing anything?
Thanks
Grant_: Nice work. You currently used the wrong units for E. Try again.
Your value of E should be in MPa in the equation (i.e. N and mm = MPa). So E = 200000e6. So answer is 3.8 mm?
I usually cross check structural calculations like this with BeamCALC or some other tool.
The bookkeeping along with units variations can cause errors to creep in.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
