The discussion revolves around determining the appropriate thickness of steel for a 20-foot water cylinder with a piston, considering the weight of the water and the design of the piston. Participants explore various factors affecting the structural integrity and performance of the cylinder and piston system.
- Technical explanation, Debate/contested, Experimental/applied
- One participant suggests that a 1/4 inch pipe wall thickness should be sufficient to support the weight of the water, but notes that the diameter of the pipe is a crucial factor.
- Another participant emphasizes that any thickness will bend under load, questioning how much bending is acceptable and discussing the importance of the piston seal design.
- A participant mentions the pressure generated by the water column, estimating it to be about 10 psi, and discusses the implications for piston design, including the need for a circular plate with a cylindrical skirt for sealing.
- One participant expresses concern about the bending of the piston and describes a design involving a vertical shaft to maintain alignment and a rubber sealing system.
- Another participant provides a range for the outer tube wall thickness, suggesting between 0.8mm and 12mm, and notes the necessity of detailed engineering analysis and drawings for accurate assessment.
- There is a suggestion that using thinner materials could be feasible, with a recommendation to test by increasing thickness if bending occurs.
Participants do not reach a consensus on the specific thickness required for the steel or piston, with multiple competing views on acceptable bending and design considerations remaining unresolved.
Participants highlight the need for additional information, such as the diameter of the pipe and detailed design drawings, to perform a valid engineering analysis. The discussion reflects uncertainty regarding the tolerable limits of bending and the specific requirements for sealing mechanisms.
