How to bias a transistor into cutoff
  • Thread starter Thread starter zak8000
    Bias Transistor
This discussion focuses on biasing a transistor into cutoff, specifically targeting a transistor with a collector cutoff current of 100nA. The user outlines their approach using DC analysis, calculating Vth and Rth with the equations Vth=5*(R10/(R10+R4)) and Rth=(R4*R10)/(R10+R4). They express uncertainty about the relationship between Ic and Ib at cutoff and consider adjusting resistance values to ensure Ic remains below 100nA, thereby achieving cutoff. The application of the circuit is identified as RF applications.
  • Understanding of transistor biasing techniques
  • Familiarity with DC analysis in electronic circuits
  • Knowledge of RF circuit design principles
  • Proficiency in using circuit analysis equations
  • Study the impact of resistor values on transistor biasing
  • Learn about the characteristics of RF transistors
  • Explore advanced DC analysis techniques for transistor circuits
  • Investigate methods to measure collector cutoff current accurately
Electronics engineers, RF circuit designers, and students studying transistor biasing and DC analysis will benefit from this discussion.
zak8000
hi
i would like to bias a transistor into cutoff. i have the schematic shown below and for the transistor i am using it has a collector cutoff current at 100nA. so my approach was frist to perform Dc analysis:
Vth=5*(R10/(R10+R4)) Rth=(R4*R10)/(R10+R4)
so my input equation is:
Vth=Rth*Ib+0.9+Ie*R12
and output equation is:
5=Vce+Ie*R12
i would ussually say Ie=Ib+Ic=(B+1)Ib but i don't think this equation holds at cutoff so should i assume Ic>100nA like 105nA so the amplifier will be in the active region(so i can use Ic=B*Ib) and then increase resistance values so Ic<100nA and the transistor will be in cutoff please help!
zak8000 said:
hi
5=Vce+Ie*R12
Looks like the schematic did not post. Can you try again? What is the application for the circuit?
ops i taught i attached it. anway i figured it out, it is used for RF applications
