- 1,575
You would only if the 5 resistors are of the same ohm value.
With six gauge wire the resistance of the coil will be close to 0.DHS Science said:Last night i went out and bought a pack of 2 resistors that allow 100 ohms and 10W. So if hook both of them up parallel in the line then i should be fine? Because if i do then the power will be divided evenly between the two resistors and will still only allow 10W thru in all, correct?
DHS Science said:If we were to use a power cord from a computer then how much power (amps, volts, watts) would that allow to enter the magnet if we were getting our power straight out of the wall?
Sorry if I am asking stupid questions but I would really like it if we would not burn the school down.
DHS Science said:The power cord does not give an answer directly if just gives (what appears to me at least) a random configuration of numbers and letters.
Averagesupernova said:Why the heck is this still in this section of the forums? Someone move this to electrical engineering.
DHS Science said:We decided to use a car battery so it is pushing out 12 volts and the wire that we are using is still getting really hot. In order for the coil to maintain the same strength we hooked a battery charger up to it, which did the job but should we put a breaker (like from a fuse box) in it to help maintain the amount of amps?
