How to calc force from natural gas?
Calculating the force from a natural gas explosion involves determining the energy released from the gas volume, which is based on the explosive limits of the gas. The wall area is 875 square feet with a depth of 0.25 feet, leading to a volume of 219 cubic feet for gas expansion. The explosive limits indicate that the gas volume can range from 8.76 to 32.85 cubic feet, translating to energy values between 7,037,784 ft*lbf and 26,391,690 ft*lbf. To find a distributed load in lb/ft, dividing the total energy by the wall length is suggested. A more accurate approach includes calculating the gas energy, temperature increase, and pressure change using the ideal gas equation.
doug12345
Hi, I'm looking for some help in calculating the amount of force from natural gas exploding. Part of the problem is that it causes a wall from a house to fail first. Area of wall 875 SF. Wall depth .25 ft. I was going to assume the whole wall to be the boundry conditions for the volume that gas can fill. (V=219 CF)
The explosive limits of the gas can be 4%-15% of volume. (Vgas=8.76 to 32.85 CF)
Then from wikipedia I found 1 CF gas = 1030 BTU, 1 BTU = 780 ft*lbf (ft-lbs-force)
Next 8.76*(1030)*(780)= 7037784 ft*lbf to 26391690 ft*lbf
Is it then possible to divide the 7037784 ft*lbf by the length of the wall to obtain a distributed load in lb/ft? Am I even approaching this problem correctly?
Thanks
A better approach would be:
1. Calculate the energy of the gas.
2. Divide it by mass of the air inside the room*specific heat if the air
to get the increase of temperature.
3. Use ideal gas equation to calculate the change of pressure (p2/p1=T2/T1).
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
