How to calculate how many threads I can use?
  • Thread starter Thread starter perky416
    Threads
The discussion revolves around the design of a new valve for a pressure cylinder, specifically focusing on calculating the minimum thread engagement required to prevent stripping under pressure. Participants explore the implications of using different materials for the fitting and the associated risks of modifying the design.
  • One participant seeks to reduce the thread engagement length from 10mm to 5mm while ensuring safety under a pressure of 232 bars.
  • Another participant questions the actual tension load on the bolt and highlights the uncertainty of the cylinder's material properties.
  • A participant expresses concern about the safety of the project, questioning the original poster's background and experience in engineering.
  • There is a discussion about the adequacy of the cylinder threads to handle the pressure, with one participant asserting that the existing threads are sufficient based on current usage.
  • The original poster mentions receiving advice from another forum, indicating that they have some guidance on the necessary calculations and considerations.
Participants express varying levels of concern regarding safety and the adequacy of the proposed design changes. There is no consensus on the safety of reducing thread engagement or the implications of using different materials.
Participants note the uncertainty surrounding the material properties of both the cylinder and the fitting, which may affect the calculations and safety of the design. The discussion includes assumptions about the load distribution on the threads and the potential risks involved in modifying the valve design.
Individuals interested in mechanical engineering, particularly in the design and safety of pressure vessels and threaded fittings, may find this discussion relevant.
perky416
Hi guys,
Here is my problem / task: I have a 232 bar pressure cylinder (not sue what material it is made from) with a brass fill valve at one end. I am trying to design a new shorter valve so that it takes up less space inside the cylinder, and thus increasing the capacity.
How would I calculate the minimum amount of threads I need to use before the pressure causes the thread to strip and the fitting comes flying out the end of the cylinder?
The original fitting has a thread engagement length of 10mm or 0.393 inches and uses an M25 x 1.0mm pitch thread. I have tried to use the following formula however it gives me an answer of 0.92904 inch / 23.59mm which is over twice the amount of the original fitting.
I understand that the first 6 threads take all the load, but If i use a stronger material for the fitting, say 303 stainless steel, can I get away with less threads?
I am trying to get the thread engagement length down to 5mm however I just don't know how to calculate it.
Regards
What is the actual tension load on the bolt?
If you don't know the pressure cylinder material then changing from brass to steel bolts won't guarantee anything.
Hi,
I have no idea what tension load is, the first time I have ever dealt with designing threads.
The cylinder is some sort of hardened steel, possibly a form of gun steel, although there is no way I can know for sure. The cylinder threads can easily take the pressure its the threads on the fitting that I am unsure about.
How do you know the cylinder threads can easily take the pressure?
This sounds pretty dangerous. What is your background (education and design experience)? Why were you assigned this task if you have no experience with this sort of thing?
Because that's the pressure it currently runs at :s, its an already made pressure cyclinder on a product...all I am doing is trying to increase the capacity.
I wasnt assigned it its a personal project. My experience is aerospace/electronics/manufacturing engineering/machining/mechanics.
Im not some dum secondary school kid that knows nothing about engineering, I am just trying to do something and seeking a bit of help.
Someone an a different engineering forum has explained what i need to do...what i need to take into account and given me the formulas with good explanations.
I never claimed you were dum [sic]. The PF rules prohibit dangerous discussions, and depending on your background and level of experience, what you are asking about can be dangerous. Hope the advice you got was good -- please be careful and stay safe.
  • · Replies 42 ·
12K
  • · Replies 45 ·
