How to calculate percentage of water vapour that condenses?
The calculation of the percentage of water vapor that condenses from 1 kg of moist air at 70% relative humidity (RH) and 21°C, cooled to 5°C at constant pressure (1 bar), results in a condensation percentage of 50.5%. The initial vapor pressure at 21°C is 0.025 bar, while at 5°C it is 0.0087 bar. The calculations involve determining the mass and mole fractions of water vapor and dry air, leading to the conclusion that 5.5 grams of water condenses from the initial 10.9 grams of water vapor present.
  • Understanding of relative humidity (RH) and vapor pressure concepts
  • Knowledge of the ideal gas law and its application
  • Familiarity with mass and mole fraction calculations
  • Basic thermodynamics related to phase changes of water
  • Study the ideal gas law and its implications in thermodynamic processes
  • Learn about phase changes and the Clausius-Clapeyron equation
  • Explore calculations involving humidity ratios and their applications
  • Investigate the effects of temperature and pressure on vapor pressure
Students in thermodynamics, environmental scientists, and professionals in HVAC (Heating, Ventilation, and Air Conditioning) who require a deeper understanding of moisture condensation in air systems.
Rhaegal
1kg of moist air of RH 70% at 21oC is cooled at a constant pressure of 1 bar to 5oC. The vapour pressure at 21oC and 5oC are 0.025 bar and 0.0087 bar. The percentage of water vapour that condenses into water at 5oC is?
Want to check whether my intuition & logic are correct.
RH = Vapour Pressure/ Saturation Pressure
Before cooling, Saturation pressure = 0.025/0.7 = 1/28 bar
As cooling & dehumidification occurs at constant pressure, Saturation pressure before cooling = saturation pressure after cooling.
RH after cooling = 0.0087 * 28 = 0.2436
% decrease of RH = ((0.7-0.2436)*100)/0.7 = 65.2 %
which equals percentage of water vapour that condenses into water.
Am I missing anything here? Because I cannot find any text to support this type of calculation.
Thanks in advance!
When they say that the vapor pressure at 21 C is 0.025 bars, what they mean is that this is the saturation vapor pressure at 21 C. This being the case, in the 1 kg of moist air under consideration, what is the partial pressure of water vapor at 21 C? What is the mole fraction of water vapor and what is the mole fraction of air? What is the mass fraction of water vapor and the mass fraction of air? How many kg of dry air are the in 1 kg of the moist air? How many kg or water are in the 1 kg of moist air?
So Humidity ratio = 0.622Pv/(Pa - Pv) = mv / ma
From this, mass of dry air ma = 0.9890 kg & mass of water vapor mv = 0.011 kg
Mass fraction of water vapor = 11/1000 & Mass fraction of dry air = 989/1000
Mole fraction of dry air = 0.9824 & Mole fraction of water vapor = 0.0176
I do not know what effect cooling & dehumidification has on these values. I feel I have to use the ideal gas equation but am confused about the P,V values for both the states.
The amount of dry air in the cooled air would not change, and would still be 989.1 g, which is 989.1/29=34.11 moles. In the final air at 5 C, the partial pressure of water vapor in this air would be 0.0087 bars, and the mole fraction water vapor would be 0.0087. So the mole fraction of the dry air is 1-0.0087=0.9913. So the total number of moles of gas in the final sample would be 34.11/0.9913=34.41 moles. So the number of moles of water vapor would be (34.41)(0.0087)
=0.299 moles of water. The mass of this number of moles of water is (0.299)(18)=5.39 gm.
So, the amount of water that condenses from the moist air = 10.9 - 5.4 = 5.5 gm. So the fraction of water that condenses is 5.5/10.9=0.505 = 50.5%
I overlooked the fact that at the final state, vapor pressure is equal to saturation pressure. Thanks for helping me approach the problem correctly
  • · Replies 18 ·
  • · Replies 16 ·
32K
  • · Replies 44 ·
