How to calculate rpm of an aeolipile
The discussion revolves around calculating the rpm of an aeolipile, a type of steam engine, as part of a school project. Participants explore the principles of operation, including the forces involved, the effects of steam exit velocity, and the challenges of building the device using historical techniques.
  • Experimental/applied
  • Some participants suggest that calculating the rotational speed requires knowledge of the exit velocity of steam and the pressure inside the aeolipile.
  • Others argue that in the absence of friction and turbulence, the tangential velocity could theoretically increase indefinitely, but practical limitations will arise from losses and steam jet exit velocity.
  • There is a proposal to measure the turbine's load/speed characteristics by applying a controllable load, which could provide more useful data than theoretical calculations alone.
  • Some participants discuss the challenges of sealing the steam tubes and suggest using historical materials and techniques, such as soldering and fabric for seals.
  • A few participants mention that the original design did not rely on gas-tight seals and could be simpler to construct without modern bearings or pressure seals.
  • There is a suggestion to consider the design of a compressor within the sphere to utilize thermal energy, though some participants note this may not align with historical accuracy.
Participants express a range of views on the feasibility of calculating the rpm and the design considerations for the aeolipile. There is no consensus on the best approach to sealing or the most effective design, indicating multiple competing perspectives remain.
Participants acknowledge limitations in their calculations due to assumptions about friction, turbulence, and the historical context of materials and techniques available during the Roman era.
Readers interested in historical engineering, steam engine design, or experimental physics may find this discussion relevant.
Tinokoloski
Hi!
I am making an aeolipile as a school project, and I was wondering if you could calculate the rpm.
This is the basic principle of an aeolipile.
You should be able to calculate the rotating velocity right? Knowing the mass and ignoring any resistance.
But then you'll need the rotating force. I looked at the rocket equation, but you need to know the exiting gas velocity for that. The diameter of the nozzle is 3mm, would it be possible to calculate the velocity steam could move out of such a nozzle after calculating the pressure inside the hollow ball?
Thanks in advance!
Tino
In the absence of friction and turbulence, the tangential velocity of the wheel would increase without limit - which is what would happen in a space rocket with an engine that can run for ever. I think the limiting rotational speed will be governed entirely by the losses and the exit velocity of the steam jets.
Ah yes of course, but what formulas would you use to calculate that rotational force? Or are there just too many variables to get a reasonable answer?
You would need something like this I assume?
It is not that complicated for your turbine . You only have subsonic flow through parallel nozzles . That is not too difficult to deal with .
To answer your original question though the top speed running free is hard to estimate .
A more useful and interesting thing to do would be to put some controllable load on the turbine and measure the turbines load/speed characteristics . You could also experiment then with different arm/nozzle configurations to get best results .
Something like that probably . Then you would need to estimate the drag. I bet there's a formula somewhere for a rotating sphere and you could approximate the jets to cylinders and assume they are traveling in a straight line normal to the axis. Drag formula for a short cylinder must also be available.
Interesting school project. What are you using for seals where the steam tubes enter the rotating drum?
Tinokoloski said:
Hi!
Thanks in advance!
Tino
I would like to encourage you to consider adding this compressor design to the inside of the sphere and see if there is any usable thermal energy value between intake air and discharge through the tip jets.
The design should be changed to draw air in through the center of the rotor and then discharged into the sphere.
That's the tricky part, we have to use the materials that were available during that period of time (the roman ages). So we are going to solder the tubes to the drum and then have a sleeve bearing on one of the connecting tubes. So the only way to prevent too much steam to leak out is to use some kind of viscous lubrication right? Then of course you don't want to have too much resistance as it does not generate a lot of force.
That's an interesting idea!
However, as stated we are trying to build it with the techniques that were available in the roman ages! I don't believe this was invented back then...
Thanks for your help!
Sorry, I didn't think about the fact that you were trying to replicate the original thinking part of the process. :sorry: Best wishes for your project :smile:
Well, that is kind of tricky. Perhaps you could make some kind of stuffing box? I guess they wouldn't let you use teflon-coated packing, but you could probably come up with something that would work, even just hemp rope.
Ah yes of course! That is a good idea, we could indeed use some kind of simple fabric to make it a bit more air tight.
Thanks!
The original did not rely on gas-tight seals, as far as I'm aware.
The bracket just "pinched" the sphere, much like they picked-up big stone blocks in those days - a couple of indents and some pincers.
The sphere had pipes that went roughly to the middle - to get steam without water, and the whole thing was heated - in an open flame.
So, don't fill more than half full to start with, the centrifugal action will throw the water to the edges in full operation.
This is a lot easier to build than anything with bearings or pressure seals.
nice thing about the simple approach is that if it's a bit off-centre, wobbly, then you can change the axis points with a hammer - just deepen the indent a little as you move it a few mm in the desired direction.
Indeed. Simple is always better.
this sort of thing - the bearings do not puncture the sphere.
as you can see, if the pipes don't extend into the centre of the sphere then water will come out, and the duration will be short.
We looked into something like this, but heron specifies the bowl in the bottom containing the water and the steam traveling through the pipes to the ball on top! Of course there is no evidence that he really managed to make it, but that’s what we’re trying to find out by building it ourselves!
It has been built this way a few times, the bearing does not have to be completely air tight, as long as some pressure can build up in the ball.
  • · Replies 60 ·
  • · Replies 20 ·
