How to Calculate Work Done in a Thermodynamic Process?
7 replies · 7K views
junglep
hey guys got this question that i have been stuck on for a while.
air is expanded from 1M Pa at 327 degrees celsius to 200kPa in a closed piston cylinder device. for the process PV^1.2 = constant. calculate the work done in kJ/kg during this process
i have managed to work out the temperature after expansion using T2/T1 = (P1/P2)^(n-1/n) but i don't know how to work out the work done without knowing the mass or any of the volumes
if work = (p1v1 - p2v2)/ 1-n
then surely i need the volumes to work out the work done
any help will be welcomed
cheers
If the gaz can be considered ideal, then by conservation of the number of moles of gaz,
[tex]\nu_i = \nu_f[/itex]<br /> <br /> you must have<br /> <br /> [tex]V_f=\frac{p_fT_i}{p_iT_f}V_i[/tex]<br /> <br /> So<br /> <br /> [tex]W=\int_{V_i}^{\frac{p_fT_i}{p_iT_f}V_i}pdV = \int_{V_i}^{\frac{p_fT_i}{p_iT_f}V_i} \frac{\alpha}{V^{1.2}}dV[/tex]<br /> <br /> And substitude back [itex]\alpha = p_iV_i^{1.2}[/itex] at the end.[/tex]
but i don't know any of the volumes so this method would not work
cheers
If [itex]PV^\alpha = K[/itex] where [itex]\alpha = 1.2[/itex] (note: this is not the [itex]\gamma[/itex] for air which is 1.4), then substituting V = nRT/P gives:
[tex]P^{1-\alpha}T^\alpha = K/n^\alpha R^\alpha = K'[/tex]
So:
[tex]P_1^{1-\alpha}T_1^\alpha = P_2^{1-\alpha}T_2^\alpha = K'[/tex]
From that, work out PdV in terms of K' and T and integrate from T1 to T2
AM
If you succed, would you please post the answer junglep?
Find T2 from the relationship:
[tex]P_1^{(1-\alpha)}T_1^\alpha = P_2^{(1-\alpha)}T_2^\alpha[/tex]
so:
[tex]T_2 = \left(P_1^{(1-\alpha)}T_1^\alpha/P_2^{(1-\alpha)}\right)^{1/\alpha}[/tex]
Use PV=nRT to find V:
[tex]V_1 = nRT_1/P_1[/tex]
[tex]V_2 = nRT_2/P_2[/tex]
Integrating PdV from V1 to V2 using [itex]P = K/V^\alpha[/itex]:
[tex]W = \int_{V_1}^{V_2} PdV = \int_{V_1}^{V_2} KdV/V^\alpha[/tex]
You just have to work that out.
AM
what is n in the equation
pv = nRT?
i thought the perfect gas eqn was pv = mass * R * T
also i am not given a value for the gas constant (R). if it is any help the answer that is given in the book is in kJ/kg not in J.
pv = nRT?
n is the number of moles of the gas. R is in units of J/mole K.
This problem does not give you n or V, so assume n = 1 in which case: PV = MRT where M is the mass of one mole of air (29 g/mole). Essentially, you are working out and using the volume for one mole of air.
AM
