How to Calculate Work, Kinetic Energy, and Tension in a Block-Cart-Pulley System
The discussion focuses on calculating work, kinetic energy, and tension in a block-cart-pulley system involving a 3 kg cart and a 4 kg block. The work done by gravity on the system is identified as the negative change in potential energy, with the participant noting that gravity does not perform work on the cart itself. The participant initially miscalculated the speed of the system by using only the cart's mass instead of the total mass, leading to an incorrect final velocity. Clarification reveals that the total mass of 7 kg should be used in the kinetic energy calculations. The conversation highlights the importance of correctly applying the Work Energy Theorem and understanding the roles of different masses in the system.
Awwnutz
http://img339.imageshack.us/img339/5208/blockcartpulleyyb1.gif
A cart of mass M1 = 3 kg is attached to a block of mass M2 = 4 kg by a string that passes over a frictionless pulley. The system is initially at rest and the table is frictionless. After the block has fallen a distance h = 0.8 m:
a) What is the work Wg done by gravity on the system?
b) What is the increase in kinetic energy DK of the cart-plus-block system?
c) What is the speed |v| of the cart-plus-weight system?
d) What is the work Ws done on the cart (not the block!) by the string?
e) What is the tension T in the string?
Relevant equations
Work Energy Theorem, Kinetic Energy: (1/2)mv^2, Potential Energy
The thing that's tripping me up is how to incorporate M1 with the work done by gravity on M2. This question confuses me because of the cart. I know that the work done by gravity for this conservative system is the negative change in potential energy, but what is the potential energy of M1? I'm just having trouble figuring out all these parts. Sorry for being so vague.
I don't think gravity does any work on M1, (mgh)final = (mgh)initial. No change in potential energy, no work done.
Thats right, since the force is working in a perpendicular direction to M1 then it does no work on it.
I'm having a problem with c though, I found the work done by gravity on the system is 31.392J. So to find the speed i put it in an equation like this:
(1/2)mv(final)^2 - (1/2)mv(initial)^2 = Work done total
(1/2)(3kg)(v(final))^2 - 0 = 31.392
v(final) = 4.58m/s, but this is not the right answer. What did i do wrong?
Mass is of the entire system, which is 7kg, not 3kg.
That's exactly it. This problem just combined too many ideas i guess i just made it harder than it really was. Thanks for your help!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
