How to convert GO TO (Fortran77) to Matlab
1 replies · 3K views
Triscas
I'm translating some code from Fortran77 to Matlab and I'm struggling due to the sentence GO TO is not valid in Matlab.
Usually using sentences while I can solve the problem but in a particular case I don't know how to face it.
To put in situation, i.e:
code
line 1
line 2
128 a=a+1
if c==1 && kcount < 20 then
line
line
if (h < 30) then
go to 128
end if
end if
line
line
if (zmax == 0) go to 128
if (zmin. lt. 0.999d0*zmax) go to 128
line
end
The problem, if can be apreciated, is the go to inside the double if statement that also is in normal if statements.
If it's neccesary I could write the code.
Thanks!
on Phys.org
You will most probably need to insert a loop starting at line 128. Details will depend on how the program terminates when it doesn't "go to 128" in the last if statement you wrote. Then at every instance of "go to 128", you would replace that with "continue", such that the rest of the code would be skipped and the loop would iterate, which is what appears to be happening here.
