How to Convert Radical Expressions to Exponential Form
The problem involves converting radical expressions to exponential form, specifically focusing on expressions like (\sqrt[4]{6x})^3 and (\sqrt[4]{a^3b^5})^{1/2}. Participants are discussing the steps and rules involved in this conversion process.
  • Participants are attempting to convert radical expressions into exponential form using fractional exponents. Questions arise regarding the correct application of exponent rules and the simplification of expressions.
Some participants have provided steps for converting the first expression and are awaiting further engagement on the second expression. There is a collaborative atmosphere, with offers of help and encouragement to explore the problem independently.
One participant notes a mistake in their initial LaTeX formatting, which may have caused confusion. There is also a mention of remembering that roots correspond to fractional exponents, which is a key concept in the discussion.
trentt
The problem is (\sqrt[4]{6x})^3 And i have to convert it to exponential form, and I forgot how to do this, so i need some help.
Thank you.
[tex] (\sqrt[4]{6x})^3[/tex]
Step 1:
[tex] (({6x})^{1/4})^3[/tex]
Step 2:
[tex] ({6x})^{3/4}[/tex]
Technically, you can go farther but this is the simplest and most compact form.
Remember when you are converting the square root into a fraction before you use the fractional exponent rule that, "Roots are located on the bottom," just like how roots of a tree are located at the bottom. That should help you remember!
For example:
[tex] \sqrt[3]{x^2} = {x}^{2/3}[/tex]
Caramon said:
[tex] (\sqrt[4]{6x})^3 = ({6x}^{1/4})^3 = {6x}^{3/4}[/tex]
Technically, you can go farther but... I assume we're going to stop there.
Thanks
Actually, if anyone is still looking at this post. Could they also convert
(\sqrt[4]{a^3b^5})^{1/2} To exponential form.
I'm not very smart today.
trentt said:
Thanks
I typed the LaTeX wrong the first time, the last expression should read:
Give that one a shot yourself and tell me where you get stuck, I'll be here reading this so I can help you along. :)
[tex] (\sqrt[4]{(a^3)(b^5)})^{1/2} [/tex]
Hint: Remember roots are on the bottom, so convert the square root into an exponential expression and then do your exponent rules and simplify!
Thanks, I finished the rest of it.
