You already asked me about this, and I answered in post #5 of this thread.
What you have in this post (#33) is mostly correct, but I would change a number of things that are still incorrect or unclear if I were turning this in.
1. "Particle of mass "m" moves from fixed point O --> r' = 0"
This is wrong. The problem statement says that P is initially at a distance of a from O and that it is moving at a speed of u.
2. "Anything distance = magnitude"
As I mentioned before, there is the concept of directed distance.
3. "Since there is displacement we have [tex]\int_{|r|}^r[/tex]
The integral with limits but no integrand is meaningless. You should remove this whole line.
4. "|r'(0)| = r'(0) = a, as straight line"
This is wrong. |r'(0)| = u, the speed of the particle. |r(0)| = a.
What does "as straight line" mean?
5. "The 0 i.e. value inside bracket = gravity i.e. g/G when deriving Energy Equation"
I have no idea what you're trying to say here. Gravity is NOT a number and it is not 0.You should remove this whole line.
6. In the line where you integrate v dv you have an integral with limits of integration on the right side, but no limits of integration on the left side. You should simplify things by getting rid of the limits of integration on the right side.
Also, when you evaluate an integral that has integration limits, you don't get the arbitrary constant. Get rid of the limits of integration on the right side, but keep the constant.
7. There is no word "otherside." It should be "other side."
8. In the two lines where you go from 0.5v2 to v2 you have the same constant. When you multiply both sides of the equation by 2, the constant changes as well. If you look back at post #5 you'll see that I used a different constant, C' to indicate that we get a new constant.
