How to express space-dependent acceleration?
  • Context: Graduate
  • Thread starter Thread starter kent davidge
    Acceleration
13 replies · 2K views
kent davidge
Since the acceleration ##\vec a## is given by ##\vec a = \frac{d^2 \vec x}{dt^2}##, it is a function of ##t## only. Of course, the derivative implies that ##t = t(\vec x)## so we can also in principle express ##\vec a## in terms of ##\vec x##. But how can we express an acceleration dependent on both time and space? I mean an acceleration of the type ##\vec a = \vec a(t,\vec x)##?
As you say, ##a## is a function of ##t## only: ##\vec a(t,\vec x(t)) = \vec a(t)##. Your question seems to suppose a specific trajectory or something, so that ##t=t(\vec x)## where now ##\vec x## is the independent variable ? Meaning that for every position there is a time assigned ?
How would that work with e.g. a circular trajectory ?
Yes, I got that. If position is time dependent, which is implied by stating that ##\vec a = \frac{d^2 \vec x}{dt^2}##, then there is really only one independent variable, namely ##t##. However it seems intuitive that in nature we should encounter situations where the acceleration depends both on space and time, so that ##\{\vec x, t \}## are independent of one another. In those cases, then what should we do?
##x## and ##t## independent of each other ? That's not a case of ##t(\vec x)##, then !
If we want to calculate a trajectory, e.g. for a mass ##m## in a gravity field from a mass ##M >> m##, we have a dependency ## \vec a = \vec a (\vec x)## and we also have ##\vec a = {d^2\vec x\over dt^2}##. After solving for ##\vec x(t)## we still don't have a ##\vec a (\vec x, t)## outside the trajectory.
:oldbiggrin:
right
then should Newton's second law be written generally as ##F(\vec x, t) = m \vec a (\vec x, t)##? and only for a specified, time-parametrized trajectory ##\vec x(t)##, can it be written as ##F = m \frac{d^2 x}{dt^2}##?
BvU said:
No. ##\vec F = m\vec a## is general: it is valid independent of ##\vec x##.
so how can we express this for a arbritary trajectory?
BvU said:
by twice differentiating the position wrt time :smile:
But I suppose that isn't what you mean ?
hmm, I think that answers my question, yes. So what can I conclude? That we can't have an acceleration of the form ##\vec a(\vec x, t)## because ##\vec x## is always ##\vec x(t)##?
A trajectory is, by definition, a smooth path through space. Thus it can be written ##\vec x(\lambda)##, where ##\lambda## is some smooth parameter along the line. Since you can only be at one place at one time and can't revisit earlier time, ##t## is a possible parameter. Thus you can write ##\vec x(t)##.
So the conclusion is that ##\vec a## (and thus, also ##\vec F##) cannot be dependent on both position and time?
You can certainly write down a time and space varying force field - Newtonian gravity around a binary star for example. But a particle can only be in one place at a time, so its acceleration at time ##t## must be expressible as a function of that single parameter.
If you fill space with matter of density ##\rho(\vec x,t)## then you could write down an acceleration field ##a(\vec x,t)##, but you appeared to be talking about a particle.
You need to be careful. If your goal is to specify the accelerations at different points for different elements, then you can write ##a(t,x)##. But if you are trying to define the acceleration of a given element as time progresses, then you must remember that ##x(t)## is already defined by the double integral of acceleration and the initial position. In that case, you are not free to specify a conflicting ##x(t)##.
