How to find energy output of a wave over the course of one hour.
To find the energy output of a wave over one hour, start by calculating the surface area of a sphere using the given distance of 4.3 meters. With the intensity of 0.026 W/m², multiply it by the surface area to determine the total power emitted by the source. Then, apply the formula Power = Energy/Time to find the total energy emitted in one hour, ensuring to convert time from seconds to hours. It’s important to maintain unit consistency throughout the calculations. This approach will yield the sound energy emitted by the source in one hour.
rzlblrt417
given the:
Intensity = .026 W/m^2
Distance = 4.3m
How much sound energy does the source emit in one our if its power output remains constant
Pmax = sqrt ( uF(w^2)(A^2))
I don't even know where to start and that is the only relevant equation that i can think. Any help would be appreciated.
rzlblrt417 said:
given the:
Distance = 4.3m
I'm not able to decipher that equation.
You are given the Power/Area for a sphere of the given radius. What is the surface area of that sphere? What does that give you for the total power being emitted by the source?
Then use the fact that Power = Energy/Time to calculate how much energy per hour will be emitted by the source. Be sure to carry units along in your calculation, because you are going to have to convert between seconds and hours at one point...
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
13K
  • · Replies 21 ·
