I How to find moment of inertia of an insect?
To find the moment of inertia of an insect, particularly a cockroach, the general formula can be applied, but the insect's complex shape may require modifications for accuracy. Data on mass and dimensions are essential, and modeling the cockroach as two partial ellipsoids could provide a more precise calculation. Understanding the limitations of the general formula is crucial for refining the model. Numerical methods may also be employed for a more tailored approach. Accurate moment of inertia calculations are vital for analyzing torque in the project.
potatoboy
Hello, I am curious to find the moment of inertia of an insect.
My guess is that I use the formula
to find the moment of inertia.
I would appreciate any help.
That is the general formula for computing moment of inertia, yes, although there are a number of shortcuts you can take depending on how precise an answer you need and what information you have.
What's the context for the problem? Why do you want to know?
And what information do you have about your insect?
Hello,
In summary, I'm doing a project on analyzing torque on a cockroach.
I have gathered data on angular acceleration of my cockroach and in order to find torque, I am required to find the moment of inertia. I have the mass and dimensions of the cockroach in g and cm respectively.
Due to the complex shape of the cockroach, I am curious if I am able to just use the general formula for it.
If you do have any suggestions, I am open to anything. :smile:
I'd read the article PeroK linked first. If the model there works for you, great. If not, then understanding why it doesn't work will help to refine what you need to put into your own model.
You could model the body as two partial ellipsoids. The moment of inertia derivation for a full ellipsoid is linked below. Maybe you can modify it to get just a part.
https://scienceworld.wolfram.com/physics/MomentofInertiaEllipsoid.html
Or you use the general formula and do it numerically.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
