How to find the cell voltage of this circuit?
The discussion focuses on calculating the cell voltage in a circuit with various resistors. The current through a 15-ohm resistor is given as 2A, leading to a calculated voltage of 30V across it. Participants clarify the relationships between currents and voltages across different resistors, ultimately determining that the voltage across the entire network of resistors should be 225V, aligning with the textbook answer. The importance of understanding series and parallel resistor configurations is emphasized throughout the conversation. The final consensus is that the total cell voltage is 225V, derived from the correct application of Ohm's law and equivalent resistance calculations.
Shadow1999
Find the cell voltage, the current at the 15 OHM resistor is 2A.
How would I solve to find the cell voltage?
I tried to find the voltage of the top part of the circuit but I just cannot remember how you would do that or if it would even result in the solution.
Do you know Ohm's law? Are you familiar with series and parallel connections? Using the given information, what is the voltage across the 15 ohm resistor?
Likes Shadow1999
Yes I am familiar with it, the voltage is 30V.
Just take it step by step...
If you know the current in the 15 ohm, this will give you the current in the 10 ohm ... from this the current in the 14 ohm ... hence the voltage across all three ... which is the voltage across the 3,4 and 4 ohm ...and so on ...
Likes Shadow1999
Right. So, what is the current through the 10 ohm resistor?
Using that, you can find the voltage across the the network containing 14 ohm, 10 ohm and 15 ohm resistors.
Also, you need to simplify the network of 3 ohm and 4 ohm resistors in order to find the current through it.
Likes Shadow1999
The current at 10 ohms would be 3A, I had figured this part out. What I can't figure out is how I would simplify and find the current through the 3 and 4 resistors. The current at 14 OHMS should be 5A?
Yes. So, what is the voltage across the 14, 10 and 15 ohm network?
What is the voltage across the 3, 4 and 4 ohm network?
Current through the network would be equal to voltage across the network/equivalent resistance of the network.
What is the equivalent resistance of the 3,4 and 4 ohm network? Can you simplify it using series-parallel reduction technique?
Likes Shadow1999
I don't know how to find the voltage across the 3, 4 and 4 ohm network.
The equivalent resistance of 3,4 and 4 ohms should be 5 ohms?
Yes.
Likes Shadow1999
cnh1995 said:
Yes.
Okay so the voltage at the 14 OHMS should be 70V (V=IR) 70=(14)(5). From what I know, 3 OHMS and 14 OHMS are parallel so they'll have the same voltage? Therefore 70/3 should be 23.3A, that's the total current across the 3,4 and 4 ohm network? So 23.3A + 5A = 28.3A. Next to find the total cell voltage I do V=(28.3)(9) which equals to 255V. Now something in my work there is wrong as the correct answer in my textbook is 225V. I've tried to figure out what I did incorrect but I just can't seem to put a finger on it. It's now 4am and I've been on this single question for over an hour.
They are not.
Right. So what is the voltage across the "entire network of 14, 10 and 15 ohm resistors"?
That will also be the voltage across the "entire network" of 3, 3 and 4 ohm resistors since these two "networks" are in parallel and not individual resistors.
I am getting the same answer.
Likes Shadow1999
cnh1995 said:
They are not.
Shouldn't the voltage across that entire network be equal to 70V as well?
What about the voltage across the 15 ohm resistor you calculated earlier?
Likes Shadow1999
70+30=100 Is it 100V?
Yes.
Likes Shadow1999
cnh1995 said:
Yes.
I understand, I had previously thought that the 15 and 10 OHM resistor had the same voltage as 14 OHMS but I was wrong. I understand that you need to find the total resistance which is 100 across the whole network. Then you divide 100 on the bottom by 20 OHMS and the top network you divide the 100 by 5 ohms which gives you a total of 25A. V=(25)(9) --> V=225v
Thank you so much for your help, you really helped me understand the concept I owe you one!
Likes cnh1995
Right.
You can also solve it by inspection only. Current through the lower network is 5A and voltage across both the networks is 100V. Knowing the equivalent resistance of the upper network as 5 ohm, current through the upper network will be 100/5=20A.
So, total current will be 25A which is nothing but the current through the 5 ohm resistor on the left. So, voltage across that 5 ohm resistor is 125V. So the cell voltage will be 125+100=225V.
You are welcome!:smile:
Likes Shadow1999
