How to find the equivalent Resistance of these circuits
The discussion revolves around finding the equivalent resistance of various resistor circuits, specifically focusing on configurations involving series and parallel combinations. The original poster presents images of circuits and seeks guidance on how to approach the calculations.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the basic principles of calculating equivalent resistance for series and parallel resistors. Some express uncertainty about how to apply these principles to the specific circuits presented. Others inquire about determining individual resistor values from a known equivalent resistance.
Participants are actively engaging with the problem, with some providing insights into the calculations involved. There is a mix of attempts to clarify concepts and explore different interpretations of the circuit configurations. No consensus has been reached, but there are productive exchanges regarding the setup and calculations.
Some participants mention the need for clearer circuit diagrams to facilitate understanding. There is also a discussion about the conditions under which the equivalent resistance is known, prompting further questions about the individual resistor values.
Aafour
Suppose that all resistors have a value of 100 ohm
how to find the equivalent Resistance of these circuits, the number in these circuits indicate the areas for which we will be completing calculations.
how to go over thesehttp://img155.imageshack.us/img155/8421/32990280.jpg
http://img24.imageshack.us/img24/6659/20062468.jpg
http://img69.imageshack.us/img69/453/10031901.jpg
thanks
Show your attempts.
Do you know how to find the equivalent resistance of series and parallel combination of resistances?
rl.bhat, yes i know how to find series and parallel combination of resistances,
for series just add the resistances, and for parallel, (1/R)=(1/R1)+(1/R2)+...
but I really don't know how to start on these circuits listed
OK. In the case 1, two resistances are in series and this combination is in parallel with the third resistance.
So 1/Req = 1/(R1 + R2) + 1/R3.
In the same way try the other combination.
true, thank you. it's just that i need to draw these circuits in more easy way. thank you
Hey! what about if i have the value of the equivalent resistance and want to work out the value of the 2 resistors that were previously there? cheers
Sorry. I didn't understand your question. Give a numerical example.
ok
Two resistors r1 and r2 connected in parallel have an equivalent resistance of 10/3 ohms.
When the current enters the parralell circuit it divides between the two resistors in the ratio of 2 to 1. Determine r1 and r2?
hope u can help :)
If 3I current flows through the parallel combination, in r1 the current is i and in r2 the the current is I2.
The voltage across the parallel combination is V = 3I*10/3 = 10*I
So the current in r1 = I = V/r1
The current in r2 = 2I = V/r2
Substitute the value of V and find r1 and r2.
  • · Replies 31 ·
