How to get maximum electrostatic force?
18 replies · 4K views · last reply
catch22
Let's take two spheres that are somewhat nearby. On one sphere, sphere A, there is Q units of charge. Now, we take some little bit of charge q off of sphere A, and put it on sphere B. What should the ratio q/Q be if we want the electrostatic force between the spheres to be a maximum?
F = K Q q / r2
[/B]
For this question, I just took plotted numbers and found that the charge q has to be half of Q in order to have the greatest electrostatic force between the spheres. So the ratio of q/Q = 1/2
How would one do this problem without plotting numbers?
Hi catch,
Do you know what the criteria are for the maximum of a function of one variable ? If so, all you need to do is write F as a function of one variable !
BvU said:
Hi catch,
unfortunately, I don't. do you mean like global maximum/minimums of a function?
I mean like if f(x) has a maximum in x0, then what about df/dx at x = x0
oh, so if I picture a graph, the highest point is where the slope is 0.
and to get the slope, we need the derivative.
Yessss! Now, what derivative ? f is easy: F. But what is a candidate for the variable x ?
q or Q?
Well, that's a no-brainer: Q is a number, so it must be q ! And now it's time to realize that the Q in the problem statement is not the Q in the relevant equation ! But you knew that, right ?
whoops, for a second I thought Q was the charge of the sphere that was taking in q.
So what is now the one-variable function you are going to differentiate with respect to ##q## ?
F = k q Q / r^2
catch22 said:
F = k q Q / r^2
whoops, should be F = k (Q-q)(q) / r^2
BvU said:
Agreed. Does it work out OK now ?
hmm, my q turned into a 1.
dF / dq = K(Q-1) / r^2 = 0
Q = 1
doesn't seem right.?:)
Ah ! So not the same as when looking at the plotted figure ?
Or perhaps a second try differentiating F = some constant times ( Qq - q2 ) ?
where did ( Qq - q2 ) come from?
BvU said:
oh, we shouldn't have factored out the q?
anyways, k (Q-2q)/ r^2 = 0
Q - 2q = 0
2q = Q
q/Q = 1/2
Bingo ! Well done.
