How to get θ sin and cos are together in 1 equation
  • Thread starter Thread starter ohaiyo88
    Cos Sin
The discussion focuses on solving the equation b2cos2θ + 2cosθ(-mb + bc2 - bz - bcsinθ) + 2sinθ(cm - cz) - c2sin2θ = p for θ in terms of constants b, c, m, z, and p. A suggested method involves substituting sin²(θ) with 1 - cos²(θ) to create a fourth-degree equation in cos(θ), although this complicates finding a simple solution. Numerical methods, particularly using software like Matlab or Mathematica, are recommended for solving the resulting equation. The Newton-Raphson method is highlighted as an effective approach for finding roots, with Wolfram Alpha provided as a useful tool for implementation. Ultimately, the discussion emphasizes the necessity of numerical solutions due to the complexity of the equation.
ohaiyo88
b2cos2θ+2cosθ(-mb+bc2-bz-bcsinθ)+2sinθ(cm-cz)-c2sin2θ=p
How to get θ in terms of b,c,m,z,p
The equation i formed to calculate the dynamic
PLs, anyone can help to solve this, i would much appreciate! I am doing my FYP!
Replace sin^2(\theta) with 1- cos^2(\theta) and sin(\theta) with \sqrt{1- cos^2(\theta)}. That will give you an equation in cos(\theta) only. However it will involve a square root so isolate that on one side of the equation and square both sides to get a fourth degree equation in cos(\theta). That is not going to give a simple answer!
Thanks for ur precious reply! Somehow i still have to go through this question.. does it has any alternative method?
HallsofIvy's approach is the right one. Do you know the values of b,c,m,z,p (or ranges)? The equation will be easily solved numerically if you do.
b,c,m,z,p are the fixed constant, they will be known later. Somehow i can't get θ if i use HallsofIvy's approach because the existence of fourth, third, second, first degree of cos θ
and also how if i want to use numerical method? how to use it ? Matlab?
Personally, I use Mathematica, but Matlab will work. A simple Newton's method solver will find the root quickly once the coefficients are known.
may i know how do i use numerical method to solve this trigo+algebraic equation? i need to equate the equation θ in terms of b,c,m,z,p
Using Newton Raphson? (i donno how to use software, only know how to use handwritten)
You could try Wolfram Alpha, which uses the Newton_Raphson method in the "FindRoot" function. For example, when I took the values, {b=1, c=2, z=3, m=4, p=5}, then using x for cos(theta), the equation becomes:
(-5 - 6 x + x^2 - 4 (1 - x^2))^2 == (-4 + 4 x)^2 (1 - x^2)
Wolfram Alpha, using the link below, finds x = -.45969. you can then find theta using the arccos function, or a calculator.
http://www.wolframalpha.com/input/?...-4+(1-x^2))^2+==+(-4+4+x)^2(1-x^2),+{x,+0.5}]
  • · Replies 18 ·
