How to get θ sin and cos are together in 1 equation
  • Thread starter Thread starter ohaiyo88
    Cos Sin
The discussion revolves around an equation involving trigonometric functions, specifically relating to the variable θ in terms of constants b, c, m, z, and p. The original poster seeks assistance in isolating θ from a complex equation that combines both sine and cosine functions.
  • Mixed
  • Participants explore the possibility of substituting sine and cosine terms to simplify the equation. One suggestion involves replacing sin²(θ) with 1 - cos²(θ) and isolating terms to derive a polynomial in cos(θ). Others inquire about alternative methods and numerical approaches to solve the equation.
There is ongoing exploration of various methods to approach the problem, including numerical solutions. Some participants have provided insights into using software tools like Matlab or Mathematica for numerical methods, while others express uncertainty about the implementation of these methods.
Participants note that the constants b, c, m, z, and p are fixed but not yet defined, which may affect the ability to solve the equation. The presence of multiple degrees of cos(θ) in the equation raises concerns about the complexity of finding a solution.
ohaiyo88
b2cos2θ+2cosθ(-mb+bc2-bz-bcsinθ)+2sinθ(cm-cz)-c2sin2θ=p
How to get θ in terms of b,c,m,z,p
The equation i formed to calculate the dynamic
PLs, anyone can help to solve this, i would much appreciate! I am doing my FYP!
Replace [itex]sin^2(\theta)[/itex] with [itex]1- cos^2(\theta)[/itex] and [itex]sin(\theta)[/itex] with [itex]\sqrt{1- cos^2(\theta)}[/itex]. That will give you an equation in [itex]cos(\theta)[/itex] only. However it will involve a square root so isolate that on one side of the equation and square both sides to get a fourth degree equation in [itex]cos(\theta)[/itex]. That is not going to give a simple answer!
Thanks for ur precious reply! Somehow i still have to go through this question.. does it has any alternative method?
HallsofIvy's approach is the right one. Do you know the values of b,c,m,z,p (or ranges)? The equation will be easily solved numerically if you do.
b,c,m,z,p are the fixed constant, they will be known later. Somehow i can't get θ if i use HallsofIvy's approach because the existence of fourth, third, second, first degree of cos θ
and also how if i want to use numerical method? how to use it ? Matlab?
Personally, I use Mathematica, but Matlab will work. A simple Newton's method solver will find the root quickly once the coefficients are known.
may i know how do i use numerical method to solve this trigo+algebraic equation? i need to equate the equation θ in terms of b,c,m,z,p
Using Newton Raphson? (i donno how to use software, only know how to use handwritten)
You could try Wolfram Alpha, which uses the Newton_Raphson method in the "FindRoot" function. For example, when I took the values, {b=1, c=2, z=3, m=4, p=5}, then using x for cos(theta), the equation becomes:
(-5 - 6 x + x^2 - 4 (1 - x^2))^2 == (-4 + 4 x)^2 (1 - x^2)
Wolfram Alpha, using the link below, finds x = -.45969. you can then find theta using the arccos function, or a calculator.
http://www.wolframalpha.com/input/?...-4+(1-x^2))^2+==+(-4+4+x)^2(1-x^2),+{x,+0.5}]
9K
  • · Replies 18 ·
