How to increase max frequency due to half cycle constraints
Designing synchronous logic with a negative edge flip-flop for data output is constrained by the setup and propagation times of the positive edge flip-flops feeding it, especially when they are physically distant, leading to clock delays that reduce maximum frequency. The clock tree structure may contribute to these delays, as it branches out to various partitions within a large chip. To enhance performance, it's suggested to minimize long paths by grouping faster components together, although the challenge remains with the inherent limitations of JTAG interfaces, which typically operate around 10 MHz. The discussion seeks methodologies to overcome the half-cycle constraints without altering the clock edge dependency of the flip-flops. Overall, participants are encouraged to share experiences or strategies to improve the design's maximum frequency.
flybanana
I'm trying to design a synchronous logic that uses a negative edge flop to shift data out of a chip (as part of the IEEE1149.1 standard). The input to this negedge flop is muxed from a whole bunch of shift registers within the chip, and these registers are all on posedges.
Ideally, if skew of clock signal between this negedge flop and the posedge flops that feed it is 0, then I know my max clock frequency is limited by
Tsetup of posedge flop + Tprop of input to output of posedge flop + Time to go through the mux + Tsetup of nedgedge flop.
However, some posedge register are situated far from the negedge flop physically on the chip, and in those cases, the clock for the posedge register is a delayed version of clock for the nedge flop, and that dramatically reduces my max clock frequency too.
Anybody have past experience designing this kind of logic and have suggestion as to how I can increase the the max frequency? (I can't want to change the clock edge dependcy of the flops)
If you want it to be fast, you shouldn't have long paths -- group the fast stuff toghether. Also, what does your clock tree look like?
I'm not too sure what the clock tree look like (somebody else did that part), but the chip is quite big and has many partitions, so I believe we have an entry point into each partition and then branches out to different logic within the partition that needs the clock.
Also because of the large size of the chip, some of registers that I mentioned that feed the TDO(test data out) negedge register is situated far away from TDO itself. But all the registers do need to go out through the TDO pad, so I am not sure what I can do to "group the fast stuff together".
How fast does your JTAG look so far in simulation? JTAG is not traditionally a blazing interface, mainly for the reasons that you are mentioning about the chip-wide nature of the scan chains.
10mhz - which is typical at most companies I think, but I'd like to look into improving that, more specifically to see if there's anything I can do about the half-cycle limitation from the posedge->negege nature of flopping the values into the final TDO register.
Thanks for your help!
So am I stuck with what I have? If anybody knows a methodology to do this, I'm much obliged. Thanks.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
