How to know that your Arduino can handle a servo motor?
To determine if an Arduino can handle a servo motor, it's essential to check the servo's current specifications, as most servos can draw significant current, often exceeding what an Arduino can supply. The Arduino should be used to control the servo with a PWM signal, while a separate power supply is recommended to power the servo itself. Connecting multiple servos, such as the Carson-model and 9G microservos, may exceed the Arduino's current limits if not powered correctly. It is crucial to ensure that the total current draw from the servos does not exceed the Arduino's capacity, which is typically in the range of a few hundred milliamps. Proper wiring and power management are key to successfully integrating servos with an Arduino.
trickybilly
I am very new to electronics. How to know if my Arduino can handle a motor? I have a "Carson-model Sport 500502015 CS3 Reflex racing servo" - is it ok and how to know? Afrotechmods said that plugging a bigger motor (anything that draws more than a few mA) would be bad for an Arduino. How can I know if it will be too much for an Arduino? I have 2 of these mentioned motors and 2 "little blue" 9G microservos. If I join all 4 for a robotic arm will that be too much?
Can you tell us what Arduino you have?
Arduino UNO R3
I believe you are talking about servos used in RC models. If so - it can't, most servos can draw quite a current (often measured in amperes) while the Arduino survives up to tens mA loads (I am not sure now whether it is 50 mA total or 200 mA total, but we are definitely speaking an order of magnitude difference).
However, when driving such a servo you don't power it from the Arduino. Arduino is there just to send the controlling PWM signal, and it can be done directly.
Servo has three wires - black goes to a common ground, red goes to the power (5 V from the BEC or UBEC or something like that), third goes to the PWM source, be it the receiver or the Arduino or whatever. All three wires are part of one cable together and typical receiver supplies the necessary power, so there is only one plug, but it doesn't have to be this way.
Likes donpacino
I also want to make a note...
An arduino is really just a special microcontroller. Normal micrcontroller you can NEVER pull current more than a few mAs out of. With arduino, there is a 5V rail that is supplied that is also used to power the microcontroller on the board. This means you can pull a few hundred mA from it (which is probably not enough for your application).
If it is enough for your application, don't fall into the trap of thinking it is the norm. You can only do this because arduinos are designed for easy prototyping.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
