How to magnetize a concrete wall?
  • Context: Undergrad
  • Thread starter Thread starter oem7110
    Concrete Wall
50 replies · 18K views
oem7110
As we know that concrete is an insulator, but if I apply extremely high voltage through this concrete at a certain level, the concrete's property may become semi-conductor. In this way, will it be possible to magnetize a concrete wall using an extremely high voltage in this way?
Does anyone have any suggestions?
Thanks in advance for any suggestions
There is no such thing as a "true" insulator because at a high enough voltage everything becomes a conductor. You would need a ridiculously high voltage for the concrete to conduct even a miniscule current. Even then the concrete won't become magnetized because the magnetic field is being generated by the electric current flowing through the concrete. As soon as the current stops the magnetic field goes away. Go read up on electricity and magnetism before you ask any more bizarre questions.
Magnetic field can magnetize any ordinary metal as shown on below video, if magnetic field is being generated by electric current flowing through the concrete, and concrete may contains any metal substance within its components, it should also be magnetized in this way, isn't it?
Does anyone have any suggestions on any mis-concept within my statement?
Thanks everyone very much for any suggestions
http://www.youtube.com/watch?v=oA3yCjjbG-0&feature=related
Is this a theoretical or practical question? In other words, what are you trying to do? Are you considering making a magnetic concrete wall, perhaps?
Concrete is a mixture containing what's called an aggregate. You could use pieces of steel for the aggregate, or you could pre-position magnets in yet-to-cure concrete. Using one of these methods, you could make a magnetic concrete wall.
Concrete contains sand too, which depends on where you live. Sand can contain quartz, magnetite, olivine, feldspar, obsidian, pieces of coral, shells, or dead sea organisms.
So in general, can I conclude that concrete wall can be magnetized if there is high enough electric current flowing through the concrete?
You can't magnetize regular concrete.
And here you are again, arguing for the sake of arguing. Will you ever start listening to the answers given.
Can you explain little more please?
if magnetic field is being generated by electric current flowing through the concrete, and concrete may contains any metal substance within its components, it should also be magnetized in this way, isn't it? It is possible, isn't it?
Of course.
There is no way to get electric current to flow trough concrete.
Even if you could, the magnetic field generated by the current would disappear once you stopped. The concrete is never magnetized.
oem7110, Yes, I do have "Does anyone have any suggestions on any mis-concept within my statement?"
Ordinary concrete is an insulator...that means you CANNOT pass an electric current through it. If you increase the voltage the concrete does NOT become a semiconductor as you wrote in the OP. So, accept (and obey) the laws of physics: you CANNOT magnetize a concrete wall.
Now, if you make concrete with metallic materials, magnets, etc. you change the above statements because it would not be "Ordinary concrete".
If lighting from Thunder hits the concrete wall, how can it be grounded if you assume that ordinary concrete is an insulator? it does not seem making any sense, isn't it? so how can I accept or obey the laws of physics from your interpretation?
Lighting very rarely strikes concrete since it's such a good insulator and it would rather go somewhere else.
When it does it causes the concrete to explode from the heat generated (the entrapped moisture expands). In theory, you can get current to pass through concrete, but it takes so much voltage that it will explode, making it completely impossible in practice.
You really like concrete!
(also, lighting doesn't come from thunder, it's the other way around)
EDIT: I would also like to point out that the concrete really isn't 'grounded', it's just busting through the concrete to get to something that is / the ground itself.
Thanks you for your interpretation, you are talking about physics now from your interpretation, so if there is no chance to get current passing through concrete before it explodes, there is no way to magnetize a concrete, right?
Thanks everyone very much for suggestions
James Leighe said:
No, there is no way to magnetize concrete because it's not magnetic.
See here: http://en.wikipedia.org/wiki/Magnetism#Sources_of_magnetism
Not everything can be magnetized.
What about radiation from space? Would radiation change the property of reinforced concrete with Steel? Radiation can get through concrete without breaking it and reach the steel. Can steel be magnetized this way? furthermore, Can concrete be magnetized by radiation?
sophiecentaur said:
No seems to have mentioned that many concrete structures are reinforced with Steel. That could change things a bit, in practice. It could explain how a particular concrete wall has been magnetised.
Thank you very much for your suggestions
We're too much into the realms of Science Fiction here. IFFFF there is steel reinforcing in concrete, it could possibly have become magnetised during electric welding. There are some heavy currents involved and that could generate a small magnetic field which could magnetise the steel.
There is no point in repeating the question about concrete becoming magnetised. The answer won't change.
What mechanism did you have in mind whereby this 'radiation' from space could magnetise ANYTHING? Are we talking Radio Frequency Radiation, Infra Red, Light, UV ? Magic rays (straight from the 1930s)?
If you want a Science discussion then you need to be Scientific!
sophiecentaur said:
We're too much into the realms of Science Fiction here. IFFFF there is steel reinforcing in concrete, it could possibly have become magnetised during electric welding. There are some heavy currents involved and that could generate a small magnetic field which could magnetise the steel. [Good Points]
OK, let focus on heavy currents only, during the thunderstorm, there are many positive charges on the ground, please see following images, could this charges magnetize the steel within concrete? the positive charges can easily get through concrete with no problem.
Do you have any suggestions?
No.
Incorrect.
A lighting strike could in theory magnetize steel however.
EDIT: Make sure you read and understood that link I gave you, it will help you tremendously.
James Leighe said:
A lighting strike could in theory magnetize steel however. [Good Points]
Could you please briefly describe more on how lighting strike magnetizes steel? what is happening during this process? Furthermore, once the steel get magnetized from lighting strike, will this magnetic property be faded as time go by?
oem7110 said:
Once the steel get magnetized from lighting strike, will this magnetic property be faded as time go by?
Not really no, it will remain magnetic for quite a while.
It will align some of the magnetic domains present in the metal.
Please read the link I gave you, it would have answered all of these questions.
@OEM
Charges do not cause a magnetic field. MOVING charges (=Current) produce a magnetic field. Heavy current pulses can flow during a lightning strikes.
If you want a chance of understanding any of this then there are certain 'rules' that apply in Physics / Science. All the terms mean something specific and you need to use them correctly and to be careful when you interpret what someone tells you. You must use Charge, Current Magnetic field etc. consistently so that we're all reading from the same hymn sheet.
A french person will laugh at you (they can be very intolerant, at times) and cannot be at all helpful if you don't use the right vocabulary when asking for the way to the station. Same with Science - vocabulary really does count. It's not just B/S.
Once steel gets magnetized, will it be no easy way to remove this magnetic property without using a thousand degrees fahrenheit? right?
Correct.
There are some complicated and expensive ways to try and demagnetize objects but only like NASA uses those.
EDIT: This turns out to not be completely true, as alternating magnetic fields applied about the object can do the job.
sophiecentaur said:
@OEM
So if I can generate some heavy current pulses into the wall, can I magnetize the reinforce concrete wall this way? Could you please tell me more about the general requirement of heavy current pulses? What heavy current pulses do on steel during this process?
In this world, because you guys are so nice, so many people from different background can understand and apply physics more.
Thank everyone very much for suggestions
You can send current through and magnetize steel, so if the steel was sticking out on at least two ends you could send current through it to magnetize it.
If the steel was fully embedded in concrete, you could place a strong magnet near it and the steel would gain some small amount of magnetism.
I'm going to suggest again that you read the link I gave you.
EDIT: *waits with bated breath for next concrete related magnetism question*
A current 'through' the steel would not magnetise it - you need the current to be at right angles to the steel you want to magnetise.
Producing a high enough magnetic field around your steel rods (assuming there are, in fact, rods in there!) is not too easy. You would need to make an electromagnet with a large diameter coil round a big lump of iron and pass a heavy current through it for a while. A car battery would give you a few hundred amps, briefly, but you would have the problem of coil resistance. You want as many turns as possible of as thick cable you can afford - only, perhaps, to find that the result is not enough for what you wanted. It could turn out to be seriously heavy engineering.
Is this for a plot line in a book!? It sounds a bit like it could be.
Assuming the reinforcing steel is in a grid pattern would it not magnetize the bars that are perpendicular to the path of the current?
I guess that's generally a bad assumption anyhow.
