How to prove that electric field propagates like a wave?
The discussion centers on the propagation of electric fields as waves, referencing Feynman Lectures on Physics Volume 1, specifically chapter 29. It establishes that static electric fields, such as those from a charge Q, do not propagate like waves, while changing electric and magnetic fields can create self-sustaining electromagnetic waves. The wave equations for electric and magnetic fields in vacuum are given as ∂²E/∂t² - c²∇²E = 0 and ∂²B/∂t² - c²∇²B = 0, highlighting the significance of the second time derivative in defining wave behavior.
  • Understanding of electromagnetic fields, including static and propagating types.
  • Familiarity with wave equations in physics.
  • Knowledge of Feynman Lectures on Physics, particularly chapter 29.
  • Basic calculus, specifically partial derivatives.
  • Study the derivation of wave equations for electromagnetic fields in vacuum.
  • Explore the implications of the second time derivative in wave mechanics.
  • Investigate the relationship between electric and magnetic fields in changing conditions.
  • Review Coulomb's law and its limitations in describing dynamic electromagnetic phenomena.
Physics students, educators, and professionals interested in electromagnetic theory and wave propagation, particularly those studying or teaching advanced concepts in electromagnetism.
Adesh
I was studying Feynman Lectures on Physics Volume 1 chapter 29. In there he proves that electric field propagates like a wave. Here is my attempt (in image), please tell me my mistake.
Thank you
I think you're getting off track. There are two types of electromagnetic fields: static and propagating. If I have a charge ##Q##, it has an associated static electric field: ##E = \frac{Q}{r^2}##. It does NOT propagate like a wave. It's constant. Similarly, a constant current density such as a current-carrying wire will produce a static magnetic field. That doesn't propagate as a wave, either.
But in empty space, far from any charges, you can still have an electromagnetic field. A changing electric field acts a "source" for the magnetic field. Similarly, a changing magnetic field acts a source for the electric field. So if both the electric field and magnetic field are changing, they can create a self-sustaining wave.
You can't derive that fact from Coulomb's law for static fields (or at least, I don't know how, maybe Feynman did).
Likes Delta2
Hi Adesh, :welcome: ,
I looked at the lecture and see that Feynman concentrates on ##(t-r/c)## to reason the disturbance propagates outward with speed ##c##. As you calculate, the amplitude diminishes with ##r##, so you get a similarity and not an exact equality.
The ##1/r## has to do with the energy radiated, that has to be distributed over an area that increases with ##r##. As Feynman explains much more clearly in 29.2
So: kudos for your efffort :smile:, point taken, but: read on !
Likes Adesh
Thank you for answering me, you can see here the way Feynman did http://www.feynmanlectures.caltech.edu/I_29.html
Thank you for being so kind. I really like your answer.
The equations of electromagnetic field in vacuum are
##\displaystyle\frac{\partial^2 \vec{E}}{\partial t^2} - c^2 \vec{\nabla}^2 \vec{E} = 0##
##\displaystyle\frac{\partial^2 \vec{B}}{\partial t^2} - c^2 \vec{\nabla}^2 \vec{B} = 0##
The fact that it's the second time derivative ##\frac{\partial^2}{\partial t^2}## in the equations is what makes these wave equations. Put a partial derivative of any other order in there, and conservation of energy is violated.
Likes Delta2
  • · Replies 65 ·
