How to record a signal outside of a physics lab?
To measure period doubling in a leaky tap, a user is exploring cost-effective methods to connect a signal to a computer without using LabVIEW or specialized external cards. They consider using a microphone plugged into the sound jack to capture drips, but are uncertain about converting that signal into a data file compatible with MATLAB. Suggestions include using a comparator and a 555 monostable to generate a pulse for easier data capture, or processing .wav files from the microphone to create a pulsed output. The user acknowledges the need for an analog to digital converter for a serial port connection, ultimately concluding that a microphone is the simplest solution. Overall, the discussion emphasizes finding accessible tools for experimental data recording outside a traditional lab setting.
gogetagritz
I am trying to set up an experiement to measure period doubling in a leaky tap. My plan was to just have a speaker input to a computer (through the com port I assume) to register drips into some container.
My web searchs for how to wire the two wires from a speaker to any port on the copmuter have so far been fruitless. I was wondering if anyone here has ever set up an experiment hooked to their computer without labview and some sort of external card made specifically for the purpose. I am hoping to do this on the cheap. Maybe I should just get a microphone and plug it into the sound jack, but I am not sure how to take that signal to a nice data file I can look at with MATLAB or something.
Any links/advice would be gratly appreciated.
Monitoring the parallel port would be much simpler, you could feed in a pulse for each event and have the software poll the pin you're using to find said events.
A microphone or leads could be fed to a comparator and then maybe even a 555 monostable to generate a pulse long enough to capture with you're polling interval whose period should be at least half that of the pulse.
Might be easier to find a way to process the .wav file from a mic in the sound card into a pulsed output file where you can set the criteria to determine when an event has occured.
http://www.soundslogical.com/support/mpacks/documentation/english/documentparts/mpack1over.html
Cliff
Yes, after spending some more time looking up pin diagrams, I realized the serial port is a digital port, requiring an analog to digital converter chip, and thus a bread board and vcc. I could scrounge those from some physics lab at school I'm sure, but wanted to keep this as simple as possible, so you are right. A microphone is the way to go. thnx for the link.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
