How to send a binary stream from Java-client to C#-server via Tcp?
  • Context: Java
  • Thread starter Thread starter user366312
    Binary Stream
39 replies · 9K views
PeterDonis said:
Why would he want to do that? He's not trying to transfer files.
Transferring a bit stream has the same inherent problems as transferring binary files. It is not dead easy - FTP has gone through several revisions.
user366312 said:
Which console? C# or Java?
Both the C# will show that it works and the Java one will show something else that may be key to your problem.
I have solved the problem. Never mind.
I thank all of you for your time and effort.
jedishrfu said:
That's great!
So what was the problem?
There was difference in r/w data format.
I am now using raw data format on both ends. I am using byte arrays.
It has some of the same inherent problems, yes. But those problems are lower level than the application/protocol level. At the application/protocol level, FTP is specialized for transferring files (which don't have to be binary, FTP has a text mode as well--not that I would recommend using it, but it has one :wink:). And actually it's not a very good protocol for transferring files, since it requires two TCP connections instead of one and coordination between the two connections (control and data) is clunky.
I am now using raw data format on both ends. I am using bye arrays.
If this work gets more involved then you might want to consider zeromq.
Its very popular for communications between disparate programs in a microservices environment, has several multi-program architectures depending on the problem, and you get extra capability that might prove useful in the future.
ZeroMQ is good for professional solutions. I doing a semester project.
But you could put it on your resume sometimes these little things make a big difference.
Okay. Thanks for the advice. I will look into that.
