How to Show the Wronskian of Three Distinct Solutions Equals Zero?
The discussion revolves around the Wronskian of three distinct solutions to a second-order linear homogeneous differential equation. Participants are exploring how to demonstrate that the Wronskian of these solutions equals zero, given that the solutions are distinct.
  • Participants are attempting to clarify the implications of having three distinct solutions and how that relates to the Wronskian. Some express confusion about the nature of the Wronskian for three functions and question the linear dependence of the solutions.
The discussion is active, with participants sharing their thoughts on the relationship between the Wronskian and linear dependence. Some have suggested that the Wronskian must be zero due to the properties of the differential equation, while others are exploring the implications of linear dependence and the conditions under which the Wronskian can be evaluated.
Participants note that the second-order differential equation can only have two linearly independent solutions, which raises questions about the linear dependence of three solutions. There is also mention of the difficulty in calculating the Wronskian directly and the implications of Cramer's rule in this context.
BrettJimison
Hello,
I was just looking for a quick tip:
If I have three distinct solutions to a second order linear homogeneous d.e, how would I show that the wronskian of (y1,y2,y3)(x)=0?
I know how to show the wronskian is not zero for a linearly independent set, but I'm confused since I'm given three distinct solutions to a second order.
I know y=c1y1+c2y2+c3y3 by the principle of super position but I'm not sure how I would go about showing a wronskian evaluated at these is zero...any tips? just need a point in the right direction
BrettJimison said:
Hello,
The Wronskian in the case of a 2nd order DE is a 2 by 2 determinant. What does the Wronskian of three solutions mean?
[Edit] Or maybe you mean the 3 by 3 Wronskian anyway? In which case you know they are linearly dependent from the DE so...
I'm trying to find a 3x3 wronskian with y1 y2 y3 that is equal to zero...not sure how to do it symbolically. It's a lot easier when I know the functions...
What theorems do you have about Wronskians and linear dependence/independence?
Well I know the set will be linearly dependet since the wronskian will equal zero. I also know that the set has to be L.D since it has 3 elements and the D.E is only 2nd order.
If
L2[ y1]=0
L2[y2]=0
l2[y3]=0
Then
y1=c1y2+c2y3
y2=c1y1+c2y3
y3=c1y1+c2y2
I then have three functions that I can plug into the wronskian...I tried this and got a soltion that doesn't seem to simplify to zero.
If
L2[ y1]=0
L2[y2]=0
l2[y3]=0
Then
y1=c1y2+c2y3
y2=c1y1+c2y3
y3=c1y1+c2y2
Also letting a=y1, b=y2, c=y3
My determinatnt simplfies to: a"(bc'-b'c)+a'(b"c-c"c)+a(b'c"-b"c')
No, you don't know that. You are trying to show the Wronskian is zero.
Yes. You do know the 3 functions are linearly dependent and that is why.
Now think about what being linearly dependent tells you about the system of equations
##c_1y_1 + c_2y_2 + c_3y_3 = 0##
##c_1y_1' + c_2y_2' + c_3y_3' = 0##
##c_1y_1'' + c_2y_2'' + c_3y_3'' = 0##
and what that implies about the Wronskian.
Well...I know If I put that into matrix form its determintant will be the wronskian. I am taking its determinant now but its not looking like its going to cancell out...
edit: I know that those equations are L.D which means they can be wriiten as linear combos of each other..
I actually get exactly what I posted previously...hmmm
The thing is: I know the set of equations is L.D and I know the wronskian will be zero. I have no idea how to show its zero though. When I take the determinant of the matrix, I don't get something that cancells
[edit] I understand why its not zero: I am basically evaluating a wronskian of a set of solutions for L3[y] so I won't equal zero...I need to find a way to get the three equations into a different form?
You aren't expected to actually calculate the determinant. You have ##n## equations in the ##n## unknown ##c_i##'s. What would you know about the ##c_i##'s if the determinant of coefficients (the Wronskian) wasn't zero? What would Cramer's rule tell you?
If the determinant wasnt zero (wronskian) then that means that there is non trivial solutions to the system which means linear dependence but I don't know how to show that since I can't compute the wronskian to show that it isn't zero...
Im pretty sure cramers rule would just tell us we could find non trivial solutions...
No. Think about what you are saying. Try a little 2 by 2 system:
##x + y = 0##
##2x - y = 0##
Here the determinant of coefficients isn't zero. Solve it with Cramer's rule.
The SPECIFIC question states:
Suppose y1,y2,y3 are three distinct solutions of L2[y] =0 on I = (a,b)
Show that W(y1,y2,y3)(x)=0 on I.
##x + y = 0##
##2x - y = 0##
Sorry meant to say if the determinant WAS zero...typo, this is what I have been trying to prove the whole time.
But what if the determinant isn't zero. What does that tell you? What does that say about your system of equations?
I have to run for now. Back in a couple of hours.
Ok Thanks for your time!
If the Det wasnt zero, then equations would be linearly independent and ONLY the trivial solution would work.
I can explain my reasoning in words, but I am having a hard time putting it into math...
Thanks!
Thanks!
There isn't much math to write, but you need to be careful about your notation. You don't talk about "equations being linearly independent" in this context. You talk about the functions ##y_1,...y_n## being independent. What you have stated above that is correct and relevant is that if the determinant is zero, you can get only trivial solutions for the ##c_i##'s. But you know the solutions are linearly dependent so there is a non-trivial solution for the ##c_i##'s. So, what do you conclude?
There isn't much math to write, but you need to be careful about your notation. You don't talk about "equations being linearly independent" in this context. You talk about the functions ##y_1,...y_n## being independent. What you have stated above that is correct and relevant is that if the determinant is nonzero, you can get only trivial solutions for the ##c_i##'s. But you know the solutions are linearly dependent so there is a non-trivial solution for the ##c_i##'s. So, what do you conclude?
W(y1,y2,y3)(x)=0 Thanks for your time and help!
