How to solve a surface double integral?
The discussion focuses on solving a surface double integral involving a sphere defined by the equation x²+y²+z²=4 and a cardioid described by r=1-cosθ. The user struggles with the integration process, obtaining an inverse sine instead of the expected natural logarithm (ln). Key insights include the recommendation to parameterize the surface in cylindrical coordinates and the importance of correctly setting integration limits. The correct setup yields an integral evaluated by Maple, resulting in the expression 8π - 8√2 + 4 ln(3 - 2√2).
  • Understanding of surface double integrals
  • Familiarity with cylindrical coordinates
  • Proficiency in integration techniques, including antiderivatives
  • Experience with mathematical software like Maple for complex evaluations
  • Study the parameterization of surfaces in cylindrical coordinates
  • Learn about evaluating surface double integrals using Maple
  • Review integration techniques for complex functions, specifically the half-angle trig identity
  • Explore tables of integrals for solving integrals of the form ∫√(1+u²) du
Students and educators in calculus, particularly those focusing on multivariable calculus and surface integrals, as well as anyone seeking to improve their skills in parameterization and integration techniques.
al_ex
surface double integral, sphere, cardioid
how do I plan the problem?
Hi I´d like a suggestion about a surface double integral. If I have a sphere x^2+y^2+z^2=4 is on the top of a cardioid r=1-cosθ. The problem is when I solve the integral I got a inverse sine when the answer is a natural logarithm (ln)
al_ex said:
Problem Statement: surface double integral, sphere, cardioid
Relevant Equations: how do I plan the problem?
Hi al_ex. Welcome to PF. You have to show some effort before anyone will help you. I would suggest you take a look at this insight article:
https://www.physicsforums.com/threa...zation-and-surface-integrals-comments.970135/Then try parameterizing your surface in cylindrical coordinates and come back if you get stuck. Also you might look at the LaTeX guide for typing equations:
https://www.physicsforums.com/help/latexhelp/
I am parameterizing dz/dx and dz/dy I got this r/(4-r^2)^(1/2) dr dθ and my parameters are from 0 to 1-cosθ and from 0 to π but when I integrate r/(4-r^2)^(1/2) dr, I got (4-r^2)^(1/2) and when I put the values 0 and 1-cosθ is where I´m starting to get a troubles because I can´´ not get in the second integration the natural logarithm I think I am planning wrongly my equations. I really need help. The answer of this problem is 8 (π -(2)^1/2-ln<(2)^1/2+1>) I don't think that the book´'s answer is wronged.
When I parameterize it with ##r## and ##\theta## I get$$
A=\int_0^{2\pi}\int_0^{1-\cos\theta}~\frac{2r}{\sqrt{4-r^2}}~drd\theta$$
for which Maple gives ##8\pi -8\sqrt 2 +4 \ln(3-2\sqrt 2)##. I think your ##\theta## limits are wrong and anything else is difficult to guess without seeing your steps.
Let me add...in a more direct response to your integration problem, while Maple easily evaluates ##\int_0^{2\pi}\sqrt{4-(1-\cos\theta)^2}~d\theta##, it gives a horribly messy antiderivative. It's no wonder you are having trouble integrating it. Once you have it properly set up I wouldn't waste any more time trying to evaluate it unless you have an appropriate software program to do it for you.
what do you suggest me? what can I do? this problem has any solution? can you give me a hint? please...
In post #4 I have given you a correct setup and a correct answer to check your work against. Assuming you agree with that, you have the problem set up correctly. Like I said in post #5, actually working out the antiderivative looks to be complicated and time consuming and a waste of time. I don't plan to waste any more time trying to do it. Ask your teacher how he/she would proceed.
LCKurtz said:
While Maple easily evaluates ##\int_0^{2\pi}\sqrt{4-(1-\cos\theta)^2}~d\theta##, it gives a horribly messy antiderivative.
It doesn't look too bad to do by hand starting with the half-angle trig identity. I got it down to an integral of the form
$$\int \sqrt{1+u^2}\,du.$$ You can look this last one up in a table of integrals.
  • · Replies 19 ·
  • · Replies 17 ·
