How to Solve Equations with Complex Numbers
9 replies · 2K views · last reply
cdummie
I have to solve the following equation:
z4=i*(z-2i)4
Now, i tried to move everything but i (imaginary number) to the left side and then find the 4-th root of i, when i did that, i had four solutions, with one of them being eiπ/8. But i don't know what to do with the left side, since i get way to complicated expression. So there must be less complicated way to solve this.
z4=i*(z-2i)4
It's not clear what you did here. Can you share the other steps you made to get everything but i to one side of the equation?
After doing the algebra, it doesn't seem like you would wind up with a simple equation like z4 - i = 0, which has as its solution of the fourth roots of i.
If I understand you, you divided both sides by [itex]z- 2i[/itex] to get [itex]\frac{z^4}{(z- 2i)^4}= \sqrt[4]{i}[/itex]. The right side has, of course, four different values. What did you get for the four values of [itex]\sqrt[4]{i}[/itex]?
Actually, i divided both sides by (z-2i)4 but i assume that you meant that.
Anyway, I got the following:
i= 0+i = cos(π/2) + isin(π/2)
then, fourth root of i is:
cos[(π/2 + 2kπ)/4) + isin[(π/2 + 2kπ)/4)
so i have the following 4 solutions:
i0=cos(π/8) + isin(π/8)
i1=cos(5π/8) + isin(5π/8)
i2=cos(9π/8) + isin(9π/8)
i3=cos(13π/8) + isin(13π/8)
but i still don't know what can i do next?@SteamKing I did exactly what HallsofIvy said.
It's still not clear how calculating i1/4 gets you any closer to finding the value of z which solves the original equation.
After all,
##\frac{z^4}{(z-2i)^4}=i^4##
but you are looking for the value of z which satisfies the equation ##z^4 = i (z - 2i)^4##.
Why didn't you expand the RHS, collect all the resulting terms on the LHS, and then solve the resulting polynomial ##f(z) = 0##?
After all,
Well, i thought, if i find the exact value on the rhs (that is eiπ/8 and three other values) and if i have ##\frac{z}{z-2i}## on the lhs then if i write a+ib instead of z (which means that z=a +ib) i could get the solution, but it turns out it isn't working. By expansion, do you mean using binomial theorem?
Yes.
Yes, it does. Once you have arrived at [itex]\frac{z}{z- 2i}= a[/itex] (where a is one of the four fourth roots of i) it follows that [itex]z= az- 2ai[/itex] so that [itex]z- az= (1- a)z= -ai[/itex] and then [itex]z= -\frac{ai}{1- a}[/itex].
Use these values for the right hand side:
##i^{\frac{1}{4}}=\left ( e^{i \frac{\pi}{2}}\right )^{\frac{1}{4}}=e^{i \frac{\pi}{8}}=\cos{\left (\frac{\pi}{8}\right)}+i \sin{\left (\frac{\pi}{8} \right )}##
I think you dropped a factor of 2 in there. ##z = az - 2ai## leads to ##z = -\frac{2ai}{1-a}##
