Dixanadu said:
Howdy! :)
Dixanadu said:
The title pretty much says it.
The answer is
The momenta conjugate to a cyclic coordinate is conserved.
I'll explain what this means below.
Dixanadu said:
Say you have a very simple 3D Lagrangian:
L = \frac{1}{2}m(\dot{x}^2 + \dot{y}^2 + \dot{z}^2) - V
So How do you tell what is conserved from a generic potential?
A coordinate is called
cyclic or
ignorable if it does not appear in the Lagrangian. The momenta conjugate to a cyclic coordinate is conserved. One has to be cautious about the meanings of these terms though. E.g. don’t confuse mechanical momentum with canonical, aka generalized, momentum. For example: Suppose you have a system described by a Lagrangian in which the x-coordinate is cyclic. Then the canonical momentum P which is conjugate to x is not necessarily p = mv. If there is a magnetic field present then
P = m
v + q
A or
P =
p + q
A where
p = m
v is the mechanical (spatial) momentum. In general
P will be conserved while
p is not.
Of course what is conserved in one coordinate system may not be conserved in another coordinate system.
Dixanadu said:
I get stuck when angular momentum gets involved. For example, what is conserved if V = V(x^2+y^2, z)...I need to know how to spot the conserved quantities generally. I know that the total energy is conserved unless there is explicit dependence on time, so don't worry about that one...
What do you mean when you say "unless there is explicit dependence on time"? I’d like to make an observation before I move on regarding pet peeve of mine. A vector field
F is said to be
conservative if curl
F = 0. If the field is conservative then it can be expressed as the gradient of a scalar function. However the scalar function might be an explicit function of time. So a vector field might be conservative in the sense that it’s the negative gradient of a scalar function V but it might not be conserved in the sense that the energy is a function of time.
Dixanadu said:
...im looking for conservation with respect to angular / linear momentum components.
Can you guys help me out please? thanks!
Absolutely. Since you know what a Lagrangian is then you must have some knowledge of analytical mechanics. The nice thing about analytical mechanics (i.e. Lagrangian and Hamiltonian mechanics) is that there is a formal procedure to determine what momenta are conserved.
A few very nice texts on analytical mechanics that I’ve read, at least in part, are
Classical Mechanics - Third Edition by Goldstein, Safko and Poole
Analytical Mechanics - Fifth Edition by Fowles and Cassiday
Analytical Mechanics with an Introduction to Dynamical Systems by Josef S. Torek
The Variational Principles of Mechanics by Cornilius Lanczos
Classical Dynamics of Particles and Systems by Marion and Thorton
There’s also a Schaum’s outline on Lagrangian mechanics that you should get at the Library of a book store. I think there are some online too. I’ll see if I can find one later tonight if I remember.
Basically if you have a potential function and you want to know if the momentum about a certain axis, let's call it the z-axis. is conserved you first apply a change in coordinates to a system in which the z-axis of your cylindrical coordinate system is the z-axis about which you wish to determine whether the angular momentum about that axis is conserved. If the polar angle is absent from the Lagrangian then the angular momentum corresponding to that angle is conserved.
