I How to start with proving ##a^a + b^b > a^b + b^a##?
  • I
  • Thread starter Thread starter MevsEinstein
    Inequalites
The discussion explores the inequality a^a + b^b > a^b + b^a, with participants sharing insights on proving it. One approach involves manipulating the expressions to show that a^y(a^{x-y}-1) ≥ b^y(b^{x-y}-1), leveraging the properties of exponential functions. Another participant presents a calculus-based argument, relating the inequality to the areas under the graph of y = e^x, demonstrating that the area under the curve increases when intervals are shifted to the right. Both methods highlight the relationship between the terms and the behavior of exponential growth. The conversation emphasizes the complexity of proving such inequalities while acknowledging the playful exploration of mathematical concepts.
MevsEinstein
TL;DR Summary
what the title says
When I learned about Catalan's conjecture, I morphed the expression ##3^2-2^3## to ##a^b+b^a##. Then, out of curiosity, I compared ##a^b+b^a## to ##a^a+b^b##. I have tried many numbers (greater that or equal to 1) for both ##a## and ##b##, noticing that ##a^a+b^b## is bigger than ##a^b+b^a##. I don't know how I am going to prove this since it contains unknown powers and a greater sign. What path should I consider taking to prove this inequality?
Mathematics news on Phys.org
I'm pretty skeptical that you can prove Catalan's conjecture with this, but let's assume ##a>b\geq 1##, and let's let ##x > y \geq 0##. We will prove##a^x + b^y \geq a^y+b^x##. Your use case is ##x=a## and ##y=b##.
##a^x+b^y=a^ya^{x-y}+b^y## and ##a^y+b^z= a^y+b^y b^{x-y}##. Both of these expressions are ##a^y+b^y## where we multiply one of the summands by some quantity. Since the summands are at least one and the multipliers are at least one, it is hopefully intuitive that if we multiply the larger summand by a larger number, the thing we get is larger overall. ##a^y>b^y## and ##a^{x-y}>b^{x-y}##, so that completes the intuitive proof.If you want to throw more algebra at it, we need to compute exactly how much larger than ##a^y+b^y## each side is
##a^ya^{x-y}+b^y = a^y(a^{x-y}-1+1)+b^y##
##=a^y(a^{x-y}-1)+a^y +b^y##
Similarly ##a^y+b^x= a^y+b^y+ b^y(b^{x-y}-1)##.
So all we have to do is prove ##a^y(a^{x-y}-1) \geq b^y(b^{x-y}-1)##. Note each side is multiplying two non negative numbers, so it suffices to prove each piece of the multiplication is larger. Since ##a>b##, ##y\geq 0## and ##x-y\geq 0##, we get ##a^y>b^y##, and ##a^{x-y} \geq b^{x-y}##. Subtracting one from the last inequality completes the proof.
I wasn't actually trying to prove it I was just playing around. Thanks for your proof by the way!
I noticed the question before noticing the nice answers, so already had this alternative answer:
a^b +b^a < a^a + b^b is equivalent to a^b - a^a < b^b - b^a. By the fundamental theorem of calculus, the left side is the area under the graph of y = e^x, between the points a.Ln(a) and b.Ln(a) an interval of length Ln(a).(b-a).
Similarly the right side is the area under the same graph between the points a.Ln(b) and b.Ln(b) an interval of length Ln(b).(b-a).
Assuming 0 < a < b, the second interval begins further to the right, and is also longer than the first interval,
so the amount of area is greater for the second interval. This holds for any increasing graph.
In this case, moving an interval to the right by an amount t>0, and keeping it the same length, increases the area by a factor of e^t > 1. and then making the interval also longer by moving the right endpoint further to the right increases the area more.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
